Help with a 1990 F150 4.9L straight 6
I am looking for any advice, tips, ideas and whatever else anyone can suggest.
It's been one issue after another with this truck. To save money I decided to do some cleaning. I took everything off all the way down to the fuel injectors. Even valve cover. Cleaned everything. I was going to replace all 6 injectors since it was only going to cost me 65 bucks. Well at least that is what I thought. Turned out to be 65 bucks a piece. Since I did not have the funds to replace them I purchases o-rings for all injectors. I cleaned them with carb cleaner. Reinstalled everything. I know I have a bad battery. This is next on my list. However I tried to jump the truck with my van. And it will not start up. I believe there is fuel getting to the rail, I am just not sure if it's getting into the cylinders. I do jot know what to do.
I am mechanical inclined I just lack the experience. And knowledge on what to look for.
Thanks
Thanks
Thanks
Thanks
End result, I will most likely have it towed to a shop and have to pay someone else to look at it.
Thanks again for everyone's help.
Replaced that about 2 years ago along with putting in a new fuel tank. I should have replaced the pump then too but didn't.
I am going to replace the solinoid and battery next. I know solinoid is going bad.
Did you ever figure anything out? Let me guess it won't start without starting fluid. But still won't start on its own..
I took my battery to work to charge it. After taking it off the charger I put a multimeter on it and you could see the charge dropping. So the battery is bad. Once I get funds to replace the battery and I will replace the starter solinoid as well I will repost the results.
