1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
VP4C3F-14B128-A 04 super duty chassis comp
Old 09-23-2015, 03:02 PM
mj_355's Avatar
mj_355
mj_355 is offline
On dads 04 f350 the 4wd first wasn't shifting to 4lo. Would do 4hi and 2wd fine. Then motor on t-case went bad. Replaced motor 2wd and 4hi still good still no 4lo. Then just 2wd so we unplugged t-case motor and power probed motor got it to do 2wd, 4hi, and 4lo. So we thinking bad dash switch but power probed it and its working fine. So we r thinking VP4C3F-14B128-A/ chassis computer bad just behind/above glovebox. R there any test we can do to confirm its bad? We called local junk yards to see bout getting one, nobody had one. If this is indeed bad where is cheapest get one? What all years use this certain chassis computer??
Old 09-23-2015, 04:42 PM
davester250's Avatar
davester250
davester250 is offline
Maybe first test what you get at the plug on the transfer case [from the computer]?
Does it get the proper signals when you switch modes?
Old 09-23-2015, 05:05 PM
mj_355's Avatar
mj_355
mj_355 is offline
no no signal at all. Checked relays. we Power probed power to 86 and got motor to move.
Old 09-23-2015, 05:09 PM
davester250
Check that the wiring is still OK [continuity between the connector at the computer and the plug on the transmission].
And that the relay is properly working when you work the switch.
Old 09-23-2015, 05:17 PM
mj_355's Avatar
mj_355
mj_355 is offline
the wiring is fine cause we can power probe to relays and unhook wire at chassis computer and get motor to work as it should. That's y we are thinking computer junk
Old 09-24-2015, 08:21 PM
mj_355's Avatar
mj_355
mj_355 is offline
plugged that chassis module back in and 4wd hi works. I don't know if maybe we just didn't have brake pushed trying it maybe. 4lo still wont engage never has for us. Just power probe jumping power at motor connector. We have never got it to by switch.
secondtonone
19
12-31-2017 03:03 PM
VAFISHER
04-14-2015 09:43 PM
Good_ol_boy
11-16-2014 08:06 PM
superCummins
11-06-2011 05:05 PM
Quick Reply: VP4C3F-14B128-A 04 super duty chassis comp
