Bronco II Ford Bronco II
1988 Bronco II A4LD Trans. Fluid Change
Old 08-03-2003, 11:48 AM
SmittyD's Avatar
SmittyD
SmittyD is offline
When I change the transmission fluid in the Bronco II, I can't get it all out. I can't find a drain plug on the convertor. Does this mean I should change the fluid more often, since I am probably only getting a third of it out?
Thanks,
Smitty
Old 08-03-2003, 05:25 PM
GrayRanger4x4's Avatar
GrayRanger4x4
GrayRanger4x4 is offline
You can drain the cooler lines and cooler, but thats about all you can get out. Just change as the owners manual says to.
I guess you could change it more often but if you arent having any trouble with it I woudln't.J,M.02 Worth
Old 08-03-2003, 07:40 PM
SmittyD's Avatar
SmittyD
SmittyD is offline
Thank you GrayRanger4X4. That makes sense.
Smitty
Old 08-26-2003, 10:44 PM
beefysbronco's Avatar
beefysbronco
beefysbronco is offline
There has to be a way to drain the torque converter. If there weren't you would take a bath every time you pull the tranny. That is if you change a tranny like I do. Lay under it, lift and push while guiding with the knees.
Old 08-27-2003, 05:45 PM
SmittyD's Avatar
SmittyD
SmittyD is offline
Thanks Beefybronco. I'll Check again.
Smitty
Old 08-27-2003, 07:31 PM
wolffpax's Avatar
wolffpax
wolffpax is offline
There isn't any drain plug on the 88 A4LD. And for some strange reason it does not give you a bath when you remove the tranny.
I am glad someone else does a tranny job like me. Beefy, I thought I was the last of a dying breed. I do it exactly the same way.
Way to go Dude!!!Keep the true tranny job technique alive!!!
Old 08-27-2003, 07:46 PM
beefysbronco
I learned about the bath the hard way about 16 years ago. I helped a buddy change out the C4 in his Granada. He drained the tranny and torque converter and pulled the driveshaft. I did the rest. I remember asking him specifically if he'd drained the Torque converter. I pulled the tranny, took the fluid bath, and from now on do it myself. Took 5 showers to get it all out of my hair. LOL
When I asked him why he told me he had drained the Torque Converter when he hadn't, he stated that he didn't know what a torque converter was and didn't want to admit it.
shameless
1966 - 1977 Early Broncos
02-21-2016 07:49 PM
neuge
Bronco II
13
04-25-2014 02:33 PM
puttster
09-16-2012 01:29 AM
gdw3138
Bronco II
06-03-2007 06:21 AM
mandigo
Bronco II
06-25-2001 09:41 AM
Quick Reply: 1988 Bronco II A4LD Trans. Fluid Change
