Which ford engine to use
Old 09-15-2015, 09:43 PM
Last chance 53's Avatar
Last chance 53
Last chance 53 is offline
A sbf is cheap , compact and great perfomer and it keeps it all Ford. But every one gets to build the truck the way they want.
Old 09-16-2015, 08:08 AM
89gtstang's Avatar
89gtstang
89gtstang is offline
I went the 351W with my build. I used many parts I had left over from my 302 mustang motor. I had to get the 351 Intake but the heads and water pump are from the 302. I didn't have any problems finding what I needed for it if I didn't already have them. I would agree though that 302 parts are easily had if needed and you can stroke the 302 to provide as much if not more HP then the 351 if that matters.
Old 09-16-2015, 09:37 AM
TonyB55's Avatar
TonyB55
TonyB55 is offline
Originally Posted by Pappys53
My 53 has a chevy 350 right now. I want to change it back to a ford. Which would be better, 351w or a 390?
The OP asked a simple question, without bashing or flaming our non-Ford powered brothers. None of the responses did any bashing or flaming of SBC power either.
Ford bashing on a Ford Truck forum seems uncalled for, in my opinion.
Can't we all just get along?
Old 09-16-2015, 11:30 AM
c91x's Avatar
c91x
c91x is offline
Originally Posted by AXracer
If the chevy is running why not leave it? Far easier to walk into any parts store and find chevy parts, much greater interchange on parts, and most any mechanic over 25 knows how to work on em. Only reason I see to change it out is for ego/peer pressure and/or because you have money to burn. (donning flame suit...) Even if the CSB in my truck blew up another one would go right back in, (especially since a good one could be quickly found, be inexpensive, and even a late model LS would bolt right in and be up and running in no time). Haters be dmaned!
We are putting a 4.6 3V with 3650 5 speed stick in Gary's 52 right now. Incompatibilities are rampant in Ford engines, I recently did some quick research on the Ford "mod" motors and was shocked at how many incompatible variants Ford built, there's nothing modular about them except bore spacing. PATS has made using a salvage late model Ford motor an almost impossible task. If going Ford, I'd stick with a pushrod engine if you can find one that hasn't been 'rode hard and put up wet". It's been discovered that many of the 351W blocks were from the factory or have developed cracks around the cam bearing journals.
Lots of parts interchange with the 4.6 its just the 3v is a ******* motor that was in production for what 5 years? With that said I'm not a fan of the mod motors and can't understand why ford even went with the 4.6 2v sohc when the 4v dohc was produced around the same time and made 280-290hp in a choked up lincoln in 93 or why not just upgrade the 302 and 351. The 351w is a bulletproof motor and the block can take 7-800hp. What google search did you read where there was a major journal problem?
Old 09-16-2015, 09:38 PM
Pappys53's Avatar
Pappys53
Pappys53 is offline
Like I said for now I will keep the 350 until I get other things done. Thank you guys for all the comments. If I get around to putting a ford in it, I am leaning towards the 302. Good engine and should get a little better gas mileage then the 351.
Old 09-16-2015, 10:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Originally Posted by c91x
Lots of parts interchange with the 4.6 its just the 3v is a ******* motor that was in production for what 5 years? With that said I'm not a fan of the mod motors and can't understand why ford even went with the 4.6 2v sohc ...
I remember when the 4.6's first came out, reading in Ward's that the 4.6 was 25% more fuel efficient and something like 30% lower emissions than the Windsors. I have no love for them but they have their strong points.
Old 09-16-2015, 10:47 PM
c91x's Avatar
c91x
c91x is offline
I bought a 97 f150 way back with a 4.6 and it made 220hp and got 12 mpg. Motor never gave me a lick of trouble though.
Old 09-17-2015, 03:30 AM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
" I want to change it back to a ford"
That´s why..................
Old 09-17-2015, 09:05 AM
OldGrayMare's Avatar
OldGrayMare
OldGrayMare is offline
I bought a 97 tbird new with the 4.6 and it still gets around 23MPG around town. Plenty of hp and the only problem I have ever had was the plastic intake manifold split, but it was covered under warranty.
If you are going with a stock motor I would go with the 351W, If you are going to build it I would go with the 302.
" I want to change it back to a ford" ===> The only reason that matters
Just my opinion, hope it helps
Old 09-17-2015, 10:50 AM
highdesert55's Avatar
highdesert55
highdesert55 is offline
That's exactly right, my dad has a nice 1940 ford truck with a 472 cadillac engine that he built 15 years ago. He has always regretted a little not keeping it all ford. I didn't want that to happen to me down the road so I chose to pony up and spend more money to have the ford engine I wanted. Its personal preference either way but at least I won't have regrets later down the road.
Old 09-17-2015, 05:21 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
HILLBILLY BOB is offline
IF you are going to change engines i would go with a 5.0-302
Old 09-17-2015, 09:32 PM
Bluey Zedoff's Avatar
Bluey Zedoff
Bluey Zedoff is offline
If it ain't broke, don't fix it, as they say.
Chev, Ford, Mopar, they are all pink inside.
I've got a SBC in mine and it would take a ton of work to get it back to a Ford mill. And for what purpose? To ease peer pressure?
You cannot please everyone. Just please yourself.
MavSprint
08-06-2012 05:19 PM
Robert R
01-13-2005 07:57 PM
jhk1981
03-23-2004 04:56 AM
john22
07-27-2003 02:28 PM
screwy
1978 - 1996 Big Bronco
01-14-2003 07:57 PM
Quick Reply: Which ford engine to use
