WD-40 Specialist long term corrosion inhibitor, better than fluid film...
When spraying oil, I cover the exhaust system with rags and block the holes in the fender that expose the manifolds with card board. I also cover the brake assemblies with garbage bags. Then I spray all the oil and let the truck sit for a day dripping onto cardboard or a tarp in the driveway. Finally, I start the truck and let it idle for 15 to 20 minutes to let anything that may have landed on the exhaust burn off. Piece of cake, just takes a little patience.
Well I picked up a can of the wd40 CI to try out.
My first impression is, it didn't go very far. I liberally sprayed it up inside the bottom of my doors though as they were pretty bad, I've already done the outsides of the door lowers with rust bullet.
But anyways, in liberally saturating the inside of the doors, both main doors and both extra cab doors, enough that I didn't stop until I saw it running out. That pretty much used the can up. I sprayed what little was left into the exposed rust inside and out of my lone rusty wheel well, and that was the end of the can.
I've not used fluid film before but the consistency of this stuff was pretty thick, reminded me of spray can adhesive when it first comes out of the can
#28
its something you can get into area which are unable to be properly prepped and painted, at least in my case.
Some guys use it to undercoat their trucks each fall to ward off corrosion.
I wire wheeled, wire brushed, prepped, primed, and painted any areas i could get too on the under body.
But areas like inside the bottoms of the doors, inside some of the metal channels under the truck and so on, one us unable to get any prep or paint in there.
in my case the Fluid film, or its WD-40 Counterpart can be sprayed up inside areas like that to coat the rust and prevent further corrosion.
#29
#30
