Crown Vic IFS
Crown Vic IFS
Guys,
Planning a F100 build, don't have the truck yet, just trying to work out all of the parts needed. I would like to convert to the crown vic IFS but don't like the idea of mismatched bolt pattern from front to rear. Just wondering if anyone has swapped in the crown vic rear using the original suspension and if so how does it look and drive? My current thoughts are to utilize the front suspension, rear end, engine and trans. I do have pretty solid fabrication skills and access to a CNC capable machine shop. I love the looks of the 4.6 with the edelbrock carb intake! I have the next year to plan as I'm in the process of heading to SWA for the Army. Like the theme of this truck, but can't pull the trigger on it at this time.
1968 FORD F100 SWB 4.6DOHC! HOT ROD TRUCK
Thanks,
rhino3
Thanks,
rhino3
https://www.ford-trucks.com/forums/1...many-mods.html
This link brings you to my build I didn't like the idea of the 2 different bolt patterns either so I bought a rear end out of a wrecked 2010 gt 500. Came with new slotted rotors, calipers and pads. Also had an aluminum Shelby diff. cover, sway bar and a watts link setup. $1200 on ebay. The rear end is the perfect with if you use mustang wheel dimensions. I am running 11"-12" rubber and I have a finger and half spacing on both sides.
mrogerstn
13
09-26-2011 04:46 PM
medicpg
24
12-07-2008 05:51 PM
medicpg
03-31-2008 12:52 PM
fivfivf100
19
08-02-2007 09:18 AM
brandontolentino
03-07-2005 12:37 PM
