View Poll Results: What would you say is reasonable for this truck? Description below
$1,000-$1,500
0%
$1,500-$2,000
0%
$2,000+
0%
Voters: 29. You may not vote on this poll
1991 F-250 $300 or $2000?
1FTEF25N5MPA25963 Can someone run a VIN report on this vehicle for me?
What would you value this rig at?
Make:
Model: F-250 XLT
Doors: 2DR
Tranny: 4 speed manual
Age: 24 years
Body: Pickup
Engine: 5.0L/302 Gasoline V8
Country: United States
Pros:
Slight misfire but engine runs strong.
Little to no rust except for the inside of the bed.
Cons:
Resprayed over stock (Peeling) "Signs of an accident"
Passenger wing window frame bent (Plexiglas)
Steering wheel was forced when locked, NO "Horn" "cruise"
Carpet was soaked and covered with moss (Gutters were clogged)
Tailgate is destroyed
Loose wires everywhere "some live"
Drill holes in bed and 3 inch cut out hole
Driver door missing inner center and has a non match panel (HANGING ON)
Electric windows/locks (Non operational) Missing parts?
Ignition broke (jury rigged) Switch under dash
Exhaust leaks and missing brackets
Power steering leaks
A/C Compressor seized
Brakes touchy
Dual tank but only one tank works
Fuel Relays bad
TAGS FEB 2011 (Emissions)
Tires no good
Interior partially dismantled
Sat for several years
No battery
# 2nd gear trouble engaging "Burn Smell when in gear"
***NO TITLE*** "waiting for a lost title process"
Cab view Couldn't keep my dog out since I got the thing!
Rear quarter view
Loose door panel "Missing door inner parts"
Loose wiring everywhere!
Column cover collar chewed up
Poor respray job
Inside Steering wheel shredded
Passenger panel cracked
Wing window and window frame are crap!
Bed into cab, rear window curved in
Make:
Model: F-250 XLT
Doors: 2DR
Age: 24 years
Body: Pickup
Pros:
Cons:
Brakes touchy
Fuel Relays bad
Tires no good
No battery
Rear quarter view
Poor respray job
Received 3,108 Likes
on
True as she would only fetch $150 but that change was my gas money to test drive it after some repairs, found that second gear is warn out and burns.
