Rear Axle U-bolt torque spec????
I did some searching but was only able to find the one post that listed the torque spec for the u-bolts/nuts for the rear axle spacers (250/350 4wd).
Can someone confirm if the info below is correct? Thanks
Tighten u-bolt nuts in 4 stages using a cross pattern.
Stage 1 - 48 lb-ft (65 Nm)
Stage 2 - 96 lb-ft (130 Nm)
Stage 3 - 148 lb-ft (200 Nm)
Stage 4 - 195 lb-ft (265 Nm)
Eric Kropp
10-31-2014 02:45 PM
