Seat swap help!!
Old 09-03-2015, 07:52 PM
Dbass1292's Avatar
Dbass1292
Dbass1292 is offline
Seat swap help!!
I'm wanting to change my seat out of my 65 cuz the springs are all broke and trashed I was wondering if a 67-72 will fit and if there is much of a size difference because the only seat frame I can find near me are out of those trucks and would the 65 seat upholstery fit the 67-72 thank you
Old 09-03-2015, 08:00 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
It sure will fit and it's an easy fix. I recently scored a black vinyl crew-cab rear seat in great shape from a guy who wants Chevrolet split-benches front and rear in his '70. His loss my gain.
Eric
Old 09-03-2015, 08:06 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
Let me add that the seat-back gets wider around '67 which causes it to hit the armrests when swung forward. Number Dummy will know more.
Eric
Old 09-03-2015, 08:10 PM
Dbass1292's Avatar
Dbass1292
So if I don't have the arm rests it should be ok and the back being wider prolly means the cover from the 66 won't fit
Old 09-03-2015, 08:11 PM
Dbass1292's Avatar
Dbass1292
So if I don't have the arm rests it should be ok and the back being wider prolly means the cover from the 65 won't fit
Old 09-03-2015, 09:02 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
Yes... but I'm not the expert. Is your upholstery good enough to re-use on a new seat?
Eric
Old 09-03-2015, 09:04 PM
Dbass1292's Avatar
Dbass1292
Ya it's not bad it's just the springs are shot and broke
Old 09-03-2015, 09:12 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
That's good news. In mine the seat foam turned to a golden dust that filled the cab every time anyone sat on it.
Eric
Old 09-03-2015, 09:54 PM
Dbass1292's Avatar
Dbass1292
I'm just looking for a new seat frame pretty much and wanted to double check that's all I gotta change wanting to make sure the 65 cover will fit the 67 frame
Old 09-03-2015, 10:07 PM
SuperSabre's Avatar
SuperSabre
SuperSabre is offline
A key part of what 6t6merc said is that the armrests (probably only, if they do at all) interfere with '67 and later seats in a '65 when you are tilting the seatback forward to access what's behind it. How often do you do that? If they interfere, just open both of the doors a bit and tilt the seatback forward. You certainly wouldn't be doing that while you are moving, so it's a minor inconvenience at best. You don't have to remove the arm rests. As it happens, I have oversized seats in my '66 and have no issues. Good luck!
Old 09-04-2015, 12:17 AM
Dbass1292's Avatar
Dbass1292
I don't have arm rests so it shouldn't be much of a problem...I was also just making sure the 65 cover will fit the 67 wider frame ok too
Old 09-04-2015, 11:58 AM
daveengelson's Avatar
daveengelson
daveengelson is offline
If recall, seats wider 67 thru the 90's. Believe the seat tracks are same from 65 thru 69, not sure from 69-72, after that need to swap the tracks with later model seats.
Acquired 67 bench seat and did not care for the backside to bench fit, felt it set too high? Went salvage shopping and found 87 Lariat 40-20-40 contoured low profile seat for the 65; since I had a spare 67 bench seat, rather than swap tracks, I swapped the backs (removed 67 back and installed the 87). Tossed the cover and padding from the 67 bench and used the 87 cover and padding as a template for the upholster shop. Had to remove an arm rest, and remove small amount of material from the bench seat retainer using a 4" grinder to prevent it from stricking the fuel tank. Pleased with results.
Jrob69f100
09-09-2014 12:05 PM
reveye
05-29-2007 03:13 PM
dapgar
1999 to 2016 Super Duty
09-18-2006 12:42 PM
1968F250LWB
01-11-2003 05:32 PM
Quick Reply: Seat swap help!!
