Diesel guys... I could use your opinion
I tend to be suspicious of mechanical "fuel problems" when the system is so entirely dependent on electrical components with known service issues, but it's easy to test and get hard facts on to rule out.
Even crank though, and started pretty smooth, which makes me think even more it's a sensor/electrical issue. ICP on an '03 is a PITA to get to, but maybe that's a starting point.
If it really is fuel drain back, I'd expect some kind of jackhammering from passing air through the injectors, no way he cranks that much with air in the secondary filter without at least some getting down into the fuel rails. When they run dry on fuel, they can still hiccup after several miles of driving, takes time to clear all the air.
Check the points and rotor people, basic tune ups every 10k
I'd also like to know why the radiator hose is double clamped? Is it old and needs replaced? Is there too much pressure in the system? You also need to get the oil temp reading warm it up to temp drive it for 15-20 miles flat ground and get the coolant and oil temps under those conditions.
Seats can be repaired without spending too much
Auto Upholstery | Leather Seat Covers | Foam Cushions | Home page
Usually an upholstery shop can fix a few panels for reasonable prices as well. It cost me around 125 to have my drivers seat repaired. Granted I have cloth seats but I dropped off the seat one day and in a few hours they had replaced 2 panels of the bottom cover and reassembled it.
I think people just got it in their heads to not use the aftermarket stuff because it saves them from remembering that they have an aftermarket filter/cap combo installed.
That aside, this truck likely has a dusted turbo and I'll bet that he's reused the aftermarket cap with a motorcraft filter. From the looks of everything else, it's likely the hard start could be from dirty fuel filters.
.....and, my god, look at the coolant in that bottle. Yikes.
If you pause the video at 0.08, you can see thick grease on the engine block. I have money on the fan clutch just spinning freely.
Once it's running, will it boost to 20?
seat bottoms $215, did mine last weekend and about 2 hours with a video on-line to help. Arm rests $70.
Degas looks to be completely full, probably why its wiped off as well.
Anybody from the forum near you with experience, maybe they could help with a knowledgeable eye?
Cold start issues could be stiction or FICM and/or glow plugs as mentioned before.
Trucks not hard to work on, just time consuming because of the extra stuff to remove getting to what you want.
Get your Torque straightened out.. did you load the PIDS for ford 6.0. probably why you couldn't see them.
Most every truck you see has at some time been neglected by an UN-knowledgeable owner. Come here, get the truck straight, why we all are here, our trucks were probably in this category to begin with and like you, seeking a fix.
Be prepared to do some maintenance right away. Good Luck with your decision!
Is there anyway to check the FICM? Not sure what the PIDS is.
#28
#30
