1979 F-800 Single Axle Dump
D3TZ-11654-A .. Headlamp Switch (Motorcraft SW-1157) / Available from Ford, the Memphis TN Ford parts depot has 103.
1973/79 F500/880 / 1973/86 C/CT600/900 & L/LN/LNT/LT/LTS600/900.
IF it has such a switch, there will be an electrical terminal on the side or near the shifter or shift tower of the transmission.
Not a truck, but something like the switch/connector:
http://www.gtoforum.com/attachments/...rse-switch.jpg
https://i.imgur.com/R32gl.jpg
Can you post the codes from you warranty/data plate? It should be on the door near the striker/latch.
Once we know the specific trans we can find a diagram of that trans.
FWIW I'd just hook it up to a switch and put an indictor light in the cab so you don't leave them on.
Last edited by 85e150; 10-03-2015 at 02:37 PM. Reason: see post 23, added correct location for this type trans
1964/72 myriad I-6 & V8 FoMoCo vehicles / 1973/76 F100/350 360/390 / 1973/78 500 and larger series trucks with FT engines / 1979 600 and larger series trucks 370/429.
D9TZ-9350-C .. 1979 370/429 Mechanical Fuel Pump / Carter - stamped on mounting flange: 60045 / Obsolete
FREESE MOTORS in Monticello IA has 2 = 319-465-3541.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
PARTS INTERNATIONAL in Farmers Branch TX has 13 = 888-727-0418.
Hey I need a little help!
Took my dash out, and now I do not have any power to the ignition switch.
Key will do nothing.
I have lights, turn signals ect.
can someone tell me were to look.
looks like the fuse panel is on the passengers side. checked the little glass fuses but they looked good. don't know what all the fuse / relay looking things are for.
any suggestions or advise would be greatly appreciated.
I must have shorted something out when moving things around getting the dash out.
Thanks Steve
Thanks Steve
#30
