Spewing oil
Spewing oil
While I'm waiting to be towed, any guesses?
The truck was running great up Cabbage Hill outside of Pendleton Oregon. Then a lot of smoke started coming out behind me and I pulled to the side. Under the hood I found a lot of oil shooting straight up from this area where I'm pointing.
What could have caused this?
It looks to be too far forward to be a turbo pedestal o-ring or EBPV valve, so high pressure oil line, or o-ring on one of the oil rail plugs are about the only things it could be.
You're sure its oil, and not fuel? The fuel line right in that area has been known to wear through, at the little line clamp holding it down, right about where your finger is, down in the valley, just ahead of the right side spider to plenum joint.
I'm voting with the schleppster, looks like a blown hpo hose. If she's down a couple quarts you'll know. Spew is the right word for when they let go! Pressure washed the valley boot on that side. Also goes to show how much oil is -not- just sitting around in the HPOP reservoir, that stuff is moving.
Are they the originals? New ones are better design with covering on the ss braid, not just loom. Make sure ya get those not NOS without it.
Glad it happened in a good place and a good time.
A mechanic stopped by last night and confirmed high pressure oil line.
On the roadside I added a gallon of oil to get to the fill line so I could drive the 200 yards to a safe place for loading onto a trailer. After that, it took another gallon just to get oil on the stick again!
Actually since you didn't spot that , I can guess you havn't a clue whats up. So if you plan on fixing that. DO NOT UNDO THE TWO FITTINGS ON THE HPOP THAT THE HIGH PRESSURE LINES ATTACH TOO. They do not come out without destroying them. The lines actually pop off of those so they stay. Many people look at that and think it just unscrews to come off. It does not. The tool I speak of slides in behind the little plastic thingy just behind the fitting and pushes it towards the hpop. This holds the lock inside the fitting, and you just pull the hose out. It will have a male end on it. Same on head. Break that fitting, and your buying a new hpop. There is a repair fitting with longer threads, but its a hoaky fix.
