1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2012 SD Rear suspension blocks
Old 08-29-2015, 04:23 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow 2012 SD Rear suspension blocks
Hey all. I have a quick question, but thinking of changing out my stock OEM rear axle blocks for the 2012 F350 SD 4x4 SRW type.
Does it matter what the wheelbase is?? Model being a CC, SC, etc?
Or...are all 2012 F350 SRW rear axle blocks the same??
Thanks,
biz
Old 08-30-2015, 08:06 PM
fishbones182's Avatar
fishbones182
fishbones182 is offline
They should be the same
Old 08-30-2015, 11:20 PM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
I think there are different ones for the different wheel bases to keep the pinion angle correct. Some are tapered and some are straight.
Old 08-30-2015, 11:45 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
If the block numbers have not changed there are two different versions based on wheel base length. See thread below for which part number's you need.
https://www.ford-trucks.com/forums/6...ar-blocks.html
Old 08-31-2015, 05:24 AM
BBsound's Avatar
BBsound
BBsound is offline
i am thinking of doing the same thing, mine sits just a tiny bit low in the rear.
how much taller are the 350 blocks?
Old 08-31-2015, 06:57 PM
dirtymutt's Avatar
dirtymutt
dirtymutt is offline
I swapped in the ready lift 4" blocks into my 2012 f250 cc sb 4x4 and they work fine. Truck sits good, looks way better loaded and has no funny vibes. I have yet to swap shocks or sway bar links with no issue.
Old 09-02-2015, 04:51 AM
Bently_Coop
F350 blocks are 3.5" while F250 are 1.5" totaling a 2" gain in the rear.
Old 09-02-2015, 05:29 AM
BBsound's Avatar
BBsound
BBsound is offline
It doesn't look quite this bad in person, i think the camera is exaggerating the sag a bit.
it sits just about level when unloaded.
Old 09-02-2015, 07:04 AM
Bently_Coop
What year is your truck? It appears from a quick search that at some point all trucks started coming with the 4" blocks because of the sag. What year is your truck? How does it feel towing like that with the nose high?
https://www.ford-trucks.com/forums/1...-rear-sag.html
Old 09-02-2015, 07:39 AM
Good listener's Avatar
Good listener
Good listener is offline
My truck was built in February and does not have 4" blocks. It did sag under load. The dealer offered to put in the appearance kit which included a new drive shaft for free. I declined that because the truck in new and I did not want future problems from the modification. I installed StableLoad wedges and the sag is gone with the ride improved under load. The sag is due to the gap left between the spring stack and the helpers. The gap is there to make the unloaded ride comfortable.
Old 09-02-2015, 07:48 AM
BBsound's Avatar
BBsound
BBsound is offline
It is a 2012. It tows that little trailer awesome, I can hardly tell its back there.
Like I said, I think the panoramic lens of the cell phone camera is exaggerating the sag.
I will look this afternoon to see what blocks it has.
Old 09-02-2015, 01:59 PM
dirtymutt's Avatar
dirtymutt
heres some before and after of my f250 with the ready lift 4" block kit. Factory f350 block is 3.5" but you can't notice the extra half inch. I've since adjusted the hitch and the truck sits even more level now.
Old 09-03-2015, 10:41 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Thanks everyone for the replies!! Really appreciate it.
I'm going to perform the Tsb 13-3-8. That is the Tsb that addresses rear sag with light loads. However, I cannot find the actual Tsb.
Can someone point me to the Tsb?? I'd like a copy before I walk into the FORD dealer to purchase the parts.
Thanks!!
biz
Old 09-04-2015, 02:41 AM
KH338's Avatar
KH338
KH338 is offline
There are three different blocks depending on the wheelbase. This is the tsb you are looking for with the necessary part numbers.
https://www.ford-trucks.com/tsbs/fulltext/?do=ViewTSB&tsbmodel=F-250&tsbyear=2013&tsbno=14-0044
Old 09-05-2015, 07:29 PM
Ginther's Avatar
Ginther
Ginther is offline
I'm about to do the same thing to my F250.
HERE in the TSB.
I also looked at this 4" block hit from 4WheelParts - Pro-Comp 4" Kit. Not sure if we need the EXP62244 or EXP62242
Haven't price out the Genuine Ford Parts vs Pro-Comp yet though.
Keep us (me) posted on what you decide. I sadly wont be attacking this project for a couple weeks or more.
Quick Reply: 2012 SD Rear suspension blocks
