My "almost" dream build
Old 08-26-2015, 06:13 PM
almercenter's Avatar
almercenter
almercenter is offline
After countless hours gleaning information from this MOST helpful of sites, I'm finally on the path to my "build".
Many thanks to all of you on this forum, my "go to source" for all things Excursion!
So, I think it's only fitting to share this w/all of you, to whom this would be possible, but much, much more difficult.
Just brought her home: July 22, 2015<br/>2005, 6.0L w/184k miles
Just dropped off today at United Automotive in Imlay City, MI to install a 2014 F550 front clip and total repaint.
When I get it back, taking to my cousin, a Certified Ford Mechanic at Saginaw Valley Ford to lift of body and swap in 2005 superduty axles and clean up and paint frame and bulletproof and freshen up the motor.
So excited!
Old 08-26-2015, 06:22 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
Are you going to lift it when you switch to coil spring front suspension ?
Old 08-26-2015, 06:25 PM
almercenter
I'm waiting to see how well my 275/70 R 18 Goodyear Duratrac's on 18X9 ProComp's fit after body work is done. I will put the modified B's on rear, and probably need a leveling kit for front at very least.
Old 08-26-2015, 06:27 PM
almercenter
Also looking to swap chrome running tubes for '14 superduty lighted black running boards. Since I'm having all plastic cladding removed, I want running boards to keep stone chips at a minimum, especially w/the more aggressive tires.
Plus, I'm vertically challenged.
Old 08-26-2015, 06:32 PM
almercenter
Good start!
Old 08-26-2015, 06:50 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
It sounds like you have quite the project underway, good luck and I'm looking forward to watching the build here!
Old 08-26-2015, 08:37 PM
2wdDezlX's Avatar
2wdDezlX
2wdDezlX is offline
I'll have to follow this since I've already got the rear quarters updated to 11+. But I'm waiting to do the front end right until I get some other things taken care of first.
Old 08-26-2015, 08:41 PM
fordboy67's Avatar
fordboy67
fordboy67 is offline
Wow, what a project! Can't wait to see the progress!
Old 08-26-2015, 08:47 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
Looks like your having fun with it...
almercenter
I know it's not really the same since I'm not actually doing all the wrench turning, but I still want to share what I can for all that I've learned from this forum.
Old 08-27-2015, 09:19 AM
Alex F's Avatar
Alex F
Alex F is offline
Oh man, the 05 front end is so much better looking than the 02.
Nice truck!!
Old 08-27-2015, 10:41 AM
devovino's Avatar
devovino
devovino is offline
nice rig
Looks like you have some big plans, I will be following along.... If you dont mind, what are they charging to paint all that acreage? And what color you going with?
Old 08-27-2015, 01:57 PM
almercenter
$5000 to do all bodywork and paint. Same gloss black.
Old 08-27-2015, 02:55 PM
Magnus E's Avatar
Magnus E
Magnus E is offline
So excited!
I like the ride!
Old 08-27-2015, 10:54 PM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
Shouldn't have to, you can fit 35's easily once they're swapped into the Excursion. Same principle as swapping out stock X leaf springs for SD springs for a lift.
Quick Reply: My "almost" dream build
