96 F150 XLT 5.0 fuel pumps not working
Old 08-28-2015, 08:37 PM
danr1's Avatar
danr1
danr1 is offline
Originally Posted by Captain Al
It's does click when key on. Without the relay in. I have no power when I turn key on?
What clicks? your short incomplete sentences aren't helping ya here.
I incorrectly assumed subfords diagrams where the same obd1 diagrams I was looking at here on my desk, missed that "F150" there for OBD II aspect in your OP.
OBD II or OBD I either way the system is the same works the same, only real difference is no can not ground fpr via diagnostic test port.
The circuits are the same colors even.
Doesn't matter if the the power makes it to the fuel pump relay on both circuits, if the computer doesn't or can't provide the ground for the relay to pull it in the pumps, neither one of them, can or will run. There will be no power to them beyond the FPR itself.
If you believe the fuel pump relay is closing then the computer and its fuel pump ground circuit is likely good the problem lies elsewhere, but its gonna be very hard to tell by "feel" with two relays working in unison next to each other.
If have doubts/and just not sure? then same test applies, find the lt blu- org wire running between the fuel pump relay socket and the PCM harness connector (looks like pin 80? but image isn't real clear) and ground it out. Then turn the key to "run" test both pumps via tank selector switch, if one or both pumps run? the problem is either the computer or its connection with the fuel pump relay socket.
If no joy manually providing ground for fpr? problem lies elsewhere but have eliminated that aspect of the system.
  #47
Old 08-29-2015, 09:30 AM
Captain Al's Avatar
Captain Al
Captain Al is offline
Good morning guys. As I said yesterday . I took off relay #2 at (fuse distr. box fender) tested for power. There is power (11 v) I turn key. No power. Did the same procedure with the relay in . Heard it click. No result.
  #48
Old 08-29-2015, 11:16 AM
Captain Al's Avatar
Captain Al
How do I check the computer ???
  #49
Old 08-29-2015, 05:00 PM
Captain Al's Avatar
Captain Al
Thanks danr1.
  #50
Old 08-29-2015, 07:06 PM
subford's Avatar
subford
subford is online now
I will ask again:
Does the fuel pump relay make (close) when you turn on the key and drop back out (open) ones second later each time you turn on the key?
  #51
Old 08-29-2015, 07:18 PM
Captain Al's Avatar
Captain Al
When I turn key on , it click. When I turn key off It does not click.
  #52
Old 08-29-2015, 07:33 PM
subford's Avatar
subford
Have you checked or replace fuse #16 in the engine compartment fuse relay box?
  #53
Old 08-29-2015, 07:50 PM
danr1's Avatar
danr1
danr1 is offline
Partially answers his question, what he wants you to do is feel for the fuel relay clicking when you turn the key to run and then feel if it clicks again a second or so later before turning off the key.
if so that would show the computer has connection with and is controlling the fpr.
With both PCM and FP relays clicking when turning the key to "run" it'll be hard to tell if both are actually getting pulled in by "feel", but would be easy to determine that secondary click, the computer timing out turning off the fuel after no start condition.
If working right you'd feel that click shortly after turning the key on but before shutting the key back off.
You have checked and replaced any and all blown fuses long before this point correct??
  #54
Old 08-29-2015, 07:54 PM
Captain Al's Avatar
Captain Al
Ok, will do. I did check all the fuses at engine compartment , they all had power. None were bad.
  #55
Old 08-29-2015, 08:08 PM
Captain Al's Avatar
Captain Al
Correct. Only one fuse seem to be bad. And I replace it, I will again check relay ( fuel relay) . And Will update you. Thanks
  #56
Old 08-31-2015, 12:06 PM
Captain Al's Avatar
Captain Al
Hi guys, i have been testing the systems. I have power up to the selector switch. I notice that when i switch (selection) for pumps. front or rear at the rear of the switch i do not have any power. i doing this at the rear of the switch. Should i have power thru the switch when i selected rear or front pumps. How do i test the switch?
  #57
Old 08-31-2015, 12:14 PM
Captain Al's Avatar
Captain Al
Let me be clear. I have power up to the selection switch. I flick selection for rear or front tanks. no power at that connection.??
  #58
Old 08-31-2015, 02:00 PM
subford's Avatar
subford
If you have power with a loading test light at the selector switch and none out the the switch is bad and you need to replace it.
  #59
Old 08-31-2015, 05:52 PM
Captain Al's Avatar
Captain Al
Thanks Subford, went thru the whole testing process. Step by step as you guys lead me. Success !!! Selector switch ! Bad! After 11days vehicle down , at last sucess!! Replace the switch. Your guys are the best. Flying is not as hard As this troubleshooting a ford, but she is my baby - Thanks!!!
  #60
Old 08-31-2015, 07:22 PM
subford's Avatar
subford
Your very welcome and yes Flying is not hard at all but it has been a few years since I have had my hands on the controls of a plane.
I do have a multi engine commercial instrument rated license.
chasencain
06-07-2019 07:51 AM
biffy626
09-10-2008 07:56 PM
xjoedirt55x
03-30-2008 12:50 PM
kaufhaus
11-06-2003 01:49 PM
brokejoker
01-12-2003 04:15 PM
Quick Reply: 96 F150 XLT 5.0 fuel pumps not working
