Troubleshooting a fuel pump
Old Jan 12, 2003 | 01:38 PM
brokejoker's Avatar
brokejoker
It's a 91 f150 5.0 efi.
The fuel pump is working when bench tested, but won't work when connected at the tank.
If it won't work at the tank, is it a relay? What else could it be if it is not a relay? Where are the relays? I have a chilton's and it doesn't give the locations of the relays.
Thanks.
Old Jan 12, 2003 | 01:43 PM
dbrown13's Avatar
dbrown13
If you have dual tanks, I would be suspect of the tank selector switch, or the wiring to the pump.
Hope this helps,
Darrell
Old Jan 12, 2003 | 04:00 PM
Racerguy's Avatar
Racerguy
The fuel pump relay is the green one under the long, skinny black cover right behind the windshield washer fluid reservoir. The EEC relay is the brown one there. Either one could cause the problem you have. Also check the inertia switch which is located on the inside of the firewall behind the clutch pedal. It has a circuit breaker type push button switch on the top of it.
Old Jan 12, 2003 | 04:15 PM
gamehunter's Avatar
gamehunter
racine
Electrical Systems/Wiring
Jan 15, 2023 06:44 PM
Ray Mathews
Jun 3, 2021 06:40 AM
86barnfind
13
Mar 25, 2017 04:51 PM
TylerF100
Oct 24, 2016 06:49 PM
lvin4jc
Nov 12, 2015 04:14 PM
