Spark plug #4 keeps going bad
Hello everyone. I hope someone can help me out. I'm getting tired of the same problem about every 6 months. Plug #4 keeps going bad. Its been doing this for years. It starts with rough idle when first starting up that clears up quickly then eventually it leads to a misfire when accelerating. Every time this happens I replace plug #4 and its good to go. Just recently (roughly 6 months ago) did a full tune up and all new injectors. About a week or 2 ago it started its rough idle at start up and just the other day it started misfiring again. What would keep causing this??
The forum needs some more background info to make informed guesses about where best to look next in your trouble shoot.
Scan the computer with your ELM scantool & post All code Number clues.
You have performed a plug read....right???? If so, post what kind of deposits are on the #4 plug that keeps failing, or if it's failing because of ceramic cracks/chips tell us which ceramic is failing. Also tell us how the Other plugs read.
What made you focus on the #4 fuel injector, then replace All injectors????
Define "Full Tune Up" for us & what mfgr parts have been used.
Did this problem begin suddenly years ago after some event, or slowly over time????
Is this problem on your 99 4.0L Ranger, if so how many miles on this puppy???
OK, good feedback.
Seeing as how this puppy has 160K miles on it, lazy switching O2 sensors belong on the suspect list for the lean code.
Since your running a oiled cotton gauze air filter, they're known to pass more dirt & if over oiled it & the dirt can migrate to & bake onto the heated MAF sensor element & corrupt its PID input to the computer about true airflow into the engine & it doesn't take much, all a vicious circle.
Yes your mechanic did a plug read. It's for deposits showing on the internal insulator, or the lack there-of can indicate a lean condition if the internal insulator looks to be really clean, cooked, blistered, eroded, chalky white, without any deposits. This read provides clues about whats going on in each cylinder.
So, since the plug read suggests all plugs are indicating a lean air/fuel ratio, use your ELM scantool, or the like, to monitor fuel trim on both cyl banks & if the air/fuel ratio is lean it'll show in the fuel trim readings. you can also monitor the upstream O2 sensors switching range & speed, to see if they're lazy. If you don't have a scantool that'll do that & you like turning your own wrenches, consider investing in the low cost ELM scantool discussed here. https://www.ford-trucks.com/forums/1...-scantool.html
Perform a fuel pressure check & volume over time test, to make sure the pump is doing its thing. PSI = 64 +/-8 & volume should be 1/2 pint/15seconds. Low fuel pump pressure or flow can cause a lean condition. EDIT: Also with 160K the PCV valve should be replaced & check its rubber hose & connections for splits, dryrot cracks, loose fit, as its down stream of & not monitored by the MAF sensor, if it is leaking vacuum from worn parts, weak spring, deposits causing it to stick open, leaking fittings, it'll corrupt fuel trim lean.
More thoughts for consideration, let us know what you find.
OK, good feedback.
All that was checked out already. MAF cleaned multiple times and also installed a new one. Trim levels showed it being lean on both banks. Got better after doing injectors. Still a little lean but not out of range to set off CEL. Fuel pressure/flow was good to the fuel rail. PCV valve was replaced after intake gaskets were done. hoses looked good. Lean code hasn't came back since doing injectors. But the misfire is returning. Someone on the ford ranger forum said its possible that the head is cracked by cylinder #4 which is why that plug keeps going bad.
OK, more good feedback.
Have you checked both upstream/before cat converter O2 sensors switching range & speed, or replaced them with like OEM design sensors???? With 160K on them they've lived 2 lifetimes & with age their switching range & speed get slow, such that their PID feedback to the computer about the exhaust O2 content is slow & behind where it needs to be for the computer to be able to adjust fuel injector squirt time fast enough to keep fuel trim within bounds. This scenario fits your input that fuel trim is "Still a little lean but not out of range to set off the CEL."
When you had everything apart to replace the intake manifold gaskets, was the lower intake manifold cleaned & if so, what did the deposit load & level look like, especially in the #4 cyl runner????
I'd consider replacing the K&N air filter with the specified Motorcraft paper filter, so you know the new MAF sensor is staying clean, if it isn't already contaminated.
The Ranger factory air intake system isn't restrictive & the OEM air filter doesn't strangle engine breathing.
Might be helpful if you'd post the Numbers you got on your tests for fuel pressure, flow rate, O2 sensor switching range & frequency/speed, STFT & LTFT.
EDIT: Is it sipping coolant over time????
OK, so its sipping coolant, so have you seen any signs of coolant contamination in the engine oil, like a chocolate milkshake like sludge on the oil fill cap, or on the dipstick, or have you had a UOA=Used Oil Analysis performed by a lab like Blackstone, to see if signs of coolant are showing up in the oil & if so is it enough to be causing excessive engine wear, by elevated wear metal numbers detected in the UOA????
This is something you need to run down right now, without further delay.
Thus a problem with the head castings, or head gasket around the #4 plug is worth putting on the suspect list.
I had a coolant sipping problem on my then new 99 4.0L that took Ford & the Dealer about a year to run down. Ford said that they were aware of porous head castings & swapped out both heads under warranty, but the problem persisted, so they replaced both head gaskets again, but this time Ford had the Dealer do it with "Revised" head gaskets in 02 & its been coolant leak tight since. So head castings & head gasket are good suspects.
You might consider performing a cylinder blow down test on #4 & see if it'll cause bubbles in the coolant at the radiator cap. Or idle it with the radiator cap removed & look for exhaust bubbles in the coolant or a strong exhaust smell at the radiator.
When you say #4 plug goes bad, whats wrong with it to call it "bad"???
The inexpensive ELM scantool running FORScan or the like software to your viewing device could let you back into the techs world for a few bucks & shorten up a trouble shoot, if you like turning your own wrenches.
If you have any of the old #4 plugs, have a close look at the internal & external ceramics for fine line cracks & let us know what you find.
A lean air/fuel mixture will cause the heads & plugs to run hot.
Are you using the Specified Heat Range Motorcraft plugs & torqueing them in to spec??? Have you been using any anti-sieze compound on the plug threads???
Has & is the cooling system & coolant been in good condition, changed on time such that its been without rust, or internal deposits, so you've been & now are getting good coolant flow to the heads. If coolant has been neglected, it can turn acidic & get after the head gaskets over time & cause leaks. It can also get after the water pump impeller blades & etch them away & cause poor circulation. Also neglect, or using hard water can cause scale, sludge & rust deposits that'll cause poor heat conduction woes in the heads, all a vicious circle.
Right now, with it sipping coolant, focus on the head gasket & passenger side head around #4 cyl.
Since your Tech said All plugs looked to have been running lean, I'd also seriously consider opting for the ELM scantool, so you can monitor fuel trim to make sure its right & staying that way.
I agree, if the upstream/before cat O2 sensors have never been replaced, its way past time to do it. The plugs, wires, fuel filter replacements are part of our scheduled maintenance replacement parts & were a good idea to do to get All past & present scheduled maintenance items up to date. I'd still seriously consider installing the specified Motorcraft air filter, so you know the MAF sensor is staying clean.
More thoughts for pondering, keep us posted on your trouble shoot findings.
Sounds like a bad head gasket to me.
Go to Oreilly's and borrow their block checker. You will have to buy the fluid.
Warm up the engine to operating temperature and check the coolant for combustion gases using the block checker.
When the engine warms up, the head and cylinder block expand due to the heat, now usually the head takes up that expansion and contains the combustion gases, but some times the pressure leaks past the gasket into the cooling passages,
Ok guys thanks for the input and all the info. Ill get all that checked out soon. This weekend he's going to do state inspection for me and we're going to replace the shocks with bilstein 4600s. Kind of excited to see how they work. Maybe we'll check out those things this weekend too while its in the shop. Thanks again PAW PAW for all your info.
Love this forum
Ok, let us know how the trouble shoot goes.
If you find the passenger side/cyl bank-1 head gasket is suspect & your going to replace it, I dug out my Dealer/Ford warranty replacement head gasket receipt & it shows the Ford "Revised" head gaskets, that have been weep/leak free for 13 years now, to be as follows, (1) YU3Z-6051-AA gasket cyl head, (1) YU3Z-6051-BA gasket cyl head.
To replace the cyl head gaskets, we also have to replace the head bolts & since your in there, consider replacing both head gaskets, upper & lower intake manifold gaskets & their Ford part numbers were as follows.
Head bolts (16) E6TZ-6065-A
Intake Manifold Gasket (1) F57Z-9439-AA
Intake Gasket (1) F57Z-9E436-AA
Cover Gasket (2) F87Z-6584-AA
