'12 f250 death wobble tires?
I am done with Ford service on my "still under warranty" pickup when it comes to death wobble. They overhauled the front end less than 500 miles ago and it helped but has gradually gotten worse to the point I can't run it any more. Can anyone recommend a tire that has helped with this problem? Currently running stock BFG rugged trail T/A 245/75R17 and would like to stay same size and a little more aggressive. Also, I see that my recently replaced track bar shock is leaking already (no doubt, a result of the wobble) and wondering what brand replacement to buy. New to the forum and did some searching - would a dual stabilizer be a help?
I have been searching around on here and I am astounded at the number of trucks with this problem.
* In the process of attempting to fix the issue, what parts did the dealer replace? One person's version of an overhaul is usually different than another.
* How severe is the wobble? You seem to indicate the vehicle is not safe to drive.
* Is the problem only when you hit a pothole, drive straight, or go around a corner? What are the conditions where the wobble becomes a problem?
* Has this vehicle ever been in an accident, hit or run over something that could have caused damage to the front suspension?
Thanks ford man, your reply is exactly what I was looking for. I believe it's gotten to the point I"ll gladly spend $735. Greatly appreciate your advise.
A little more information would be helpful:
- all bushings and ball joints from steering box down (not the steering box), new track bar and stabilizer
- you answered your own question here
- all of the above, the worst on transition from one county's tar road to another's and washboard surfaces
Its really sad that Ford owners have to spend $700+ dollars with the aftermarket to try & solve this issue that has been going on for years. Ford sent a letter out saying the problem was caused by low tire pressure.
We have 4 Super Duty trucks at work. The Chevy 2500HD I normally drive was getting its yearly safety inspection, so I had to drive a 2008 SD. About 35 miles out, while towing a 8500 pounds generator, it went in to the death wobble. I've never experienced anything like it. Talk about scary!! I thought all 4 wheels were falling off. I was SO glad to get back in the Chevy!
If you think about it, the straight front axle has been around since the first caveman put an axle between two stone wheels. The design & technology is that old. Ford needs to realize this & get in the 21st century.
We shouldn't have to spend $$$ with the aftermarket to fix problems on our new expensive trucks. Ford won't care until people start to die & they get sued for mega $$$. For now, its cheaper for them to ignore it. Just like GM with their bad ignition switches.
It never death wobbled.
The steering shock is commonly blamed for a wobble in the front end. Chances are it's more likely to be the Panhard Rod, or whatever the correct term is for the link which prevents lateral movement of the axle. That steel rod has a bushing on each end - one end goes to the frame, and the other goes to the axle. If the bushings get any play in them, the axle can shuck side to side over bumps or uneven road surfaces...giving you the feel of the death wobble. When you steer, the tie rod first has to pull the axle back into place, and then turn the wheel.
Less likely but still possible are the bushings in the radius arms - they locate the axle longitudinally so it won't move forward or backward. One end connects the axle, and the other is connected to the frame. Big bushings on both ends. Again, play here can cause a change in steering geometry.
You could replace the Ford steering damper with a "better" aftermarket, such as a Bilstein. The shock should not be leaking. But many times, the "better" aftermarkets are simply stiffer, not better.
Switching to coils in the front is a vast design improvement or front leafs.
My sincere thanks to all above who replied with helpful advice. I am going to put new tires, shocks, and the WC kit or something similar for my "made up" and "undisclosed details" problem.
