sudden RPM fluctuations in an '03
#31
Ie 0=not in sync.... correct. It should go from a 0 with KOEO to a 1 as soon as you crank it... if they function correctly. Watching the video, you have a solid ZERO. May have the wrong x-gauge information programmed for that PID... it would have not started at a 0. There is also one for FICM sync.
You need cam/crank/FICM sync to start.
What happens to the readings when its goes crazy?
ICP, FMP, ICPV are good, that SYC is suspect.
That's no good, unplugging the EGR makes the fan not work properly... it controls fan speed, not just EGR exhaust flow. Wonder if the plug has some shorted wire in it... I would check that carefully, looks like a chewed up mess!
I don't have any codes, and I don't have any issues with the fan not running the way it should. I'm deleted, no cooler or EGR.
I've read threads about this not being an issue with many owners on the early builds, just wanted some more input on this.
#32
Looks like my new friend Watson has narrowed this down by identifying the 'chewed up mess' of a wiring harness that seems to go everywhere around that engine. I've been fiddling more with it and have the engine running smoothly now with the EGR wires plugged in. So, there must be a short in there after all. How big of a job would it be to replace that whole electrical mess once and for all? Is it one part, or a bunch?
#33
Glad I could be of assistance.
Wiring harness is about $700US and not to bad of a job, about a days worth for a rookie. OR, go slow, separate that pile of headache and apply some electricians tape in the right spot followed by a little liquid electrician's tape to hold everything solid at the repair site.
Ask your mechanic why he felt the need to unplug that sensor... you'd like to know what issues he fixed or suspected by doing that.
Your near Kamloops... pretty country!
Mike,
Sure your not confusing EBP and EGR?
Mike,
#34
Mike,
Mike,
I have read countless threads of others with early builds that swear it did not affect fan operation, but I wonder if a tuner makes a difference? This truck has an SCT emblem inside the cab(one of those freebies they give you) but did not come with a tuner. I wonder if it's still got some kind of tune in the PCM, but I doubt it, although it does shift crisply..........I attribute that to the early builds being known for this attribute as well, also read in other threads.
The EBP on the other hand, has be double dog confused now. A few months back I was told early builds don't actually use the EBP for turbo action since it came from other sensors, then I was told early build EBP does in fact affect turbo operation to a good degree. So which is it? Is this inferred on early builds or not?
#35
I'm pretty sure EBP is inferred, not EGR and it will set a soft code. Have you watched fan speed on the scan gauge? it's FSS for the x-gauge. Mine has only gone above 1200rpm once and I run a 200* stat, pull a 25' trailer with quad in back, July heat in VA is HOT and never saw anything above 217*.. and that was at 70mph.. up rolling grades, 4 people in the truck and all our camping junk... even a good 1/4 cord wood for marshmallows at night.
I have a soft code for EGR always set, P0401 but no CEL... which my tuner is supposed to do.
#36
PO towed things during summer months as well, came from twin cities area, they are no stranger to heat but again, don't know that he towed anything heavy.
#37
Mike,
I'd say outside temps have less to do with engine temps than you'd believe... it's just a point to start from and always ends at t-stat open... that simple. If it's 40* outside, it goes up until the t-stat says open. If its 85* outside.... it goes up until t-stat says open. It just doesn't have as far to get there.
If everything works correctly, the trucks temp shouldn't fluctuate much. As load increases, t-stat opens and fan cools circulated water... the hotter it gets the more open the t-stat gets and fan increases. Temps fall, t-stat closes, fan drops RPM and water flow decreases... at some point its responding to slight differences in engine temp... a little more fan and faster water flow, all centered around the T-stat.
And the EGR trigger of hotter air, until that's disconnected. Your tuner tells it to use these per-programmed parameters they give it to use... well I'm pretty sure it does (a tuner would know, trade secrets).
Quizzack
13
03-29-2014 01:06 AM
bkcowboss
17
09-27-2008 04:04 PM
