SRW to DRW conversion
You can see the difference in rear axles here. https://www.ford-trucks.com/forums/1...l#post13216938
I was planning to run timkin bearings and races, but it seams as though you guys trust spicer a bit more. I dont know enough to say one is better than the other. I do know they are both high quality.
That is interesting information, but she will be getting a dana 60 hopefully. The cheapest I have found one yet is 750 bucks. Just found it today on craigslist. No info posted to it other than its a dana 60 high pinion out of a 97. I emailed him asking what the gear ratio is, and the shape its in. Have yet to hear back. I figure I can get a DRW rear axle for 100-200 bucks.
The better sterling 10.25 axle is the long pinion one
on
might want to figure that one again after you look around for a few first.you could probably source a srw or even a cab and chassis axle that cheap on a good day but the drw pickup axles go for 7-900 range.
That would be an issue. I could still come out well on it though. That is assuming the only issue is the engine. Has a nice dump bed on it. I could make my money back on the truck parting it out.
I think if the rear axle is going to be my only problem its worth the investment for as cheap as I can get it. Hope I'm not wrong
Received 3,108 Likes
on
I noticed that. Has my interest perked as to why. As long as it has the dana 60 it will be worth the investment.
#29
on
also don't forget you need a sterling with the ring tone in the rear (which started around 1989 or so i believe) for your speedo to work in the 9th gen trucks.absolute requirement for those with E4OD trans.
though pre-'93 sterling (short yoke) axles may be less desirable as pointed out by Brad,they are the only ones with 3.55 gearing in the drw pickup form.the update is mainly important for those who run large tires.if your looking for a pickup axle with 4.10's then just get the 93-97 drw pickup axle.they're easy to find in the yards all over the us.....they just cost $ lol.the freight shipping isn't horrendous,so you can pick one up with ease.
car-part.com
car-part.com
#30
If the front isn't a dana 60 I wont buy it, but if it is I can make my money back on it selling the bed alone, and would give me a new cab for my 85 trail rig. Its the only complete donor truck I've found yet that I wont be loosing money on. If not I may have to pony up the dough for a pulled dana 60.
I didnt think about the speed sensor, but I could get by with out it. Think my transfer case has a speed sensor in it if I remember correctly. Pulled it out of my 1980 before I got rid of it.
Unfortunately it keeps looking like this truck is to good to be true. SRW front end, and it looks like the right side of the axle is riding a bit higher than the left, indicating it is could be a TTB front end.
