1986 f150 no start. Need advice
I need some help. New to this forum and have looked around but can't find the exact answers I need. I have a 86 f150 with a 302 carbureted (not sure of the motor year) and 4 speed trans. Parked it one day went to start it 30 minutes later. Wouldn't even hit. Someone has wired this truck up their way so it's all confusing to me. It cranks normal. Getting fuel. I poured gas down the carb still nothing. No spark not at the plugs not the coil wire. It has the dura spark II system on it. Pretty simple but I'm still stuck. Took the ICM off (blue harness on it) which wasn't grounded? Mounted on plastic fender well. But it worked until now. Anyways the bottom of it was melted out. Replaced it. Wired up the same. Still nothing. Replaced the coil. And the distributor (a 79 302 disitrubutor matched the one I took out of it). After cranking both the icm and the coil get real hot. They have the system wired up wrong but it worked before so why not not? Maybe put a new ignition switch in it next? Any wiring schematics would be helpful. Or if someone could point me in the right direction it would be very much appreciated.
This is where someone rigged it up and I just wanna find out the right way.. There is 1 wire (white/blue) coming from the ignition, hot in the on and start side. It was then hooked up to a wire ran to a fuel pump on the frame rail and has both the icm wires (red,white) on it also. That's gotta be too much drawing off that 1 wire.
skattnig
06-12-2007 01:40 PM
Happy Hillbilly
10-07-2006 08:02 PM
