Manual Trans for 5.0 Build
Old 08-12-2015, 11:29 PM
thompsj0784's Avatar
thompsj0784
thompsj0784 is offline
So I have a 95 f150 extended cab 4.9L 5-speed Mazda that I converted to 4wd a couple years back. I don't really need the reliability of the 4.9 anymore and want to go faster. So I recently came into a 5.0 OH that I'm building to put into my truck. The problem is I know the mazda isn't going to hold up to the power of the 5.0. I plan to build the motor to push 400hp to the tire and I figure with the cam I want a similar torque figure. Does anyone have any recommendation for a MANUAL transmission that will hold up to this kind of power. I also have a turbo to put on later down the road, but I want to get the 5.0 in first and mess with that later. Being that I plan to turbo it in the future I would like an overdrive trans. Any help would be greatly appreciated Thanks in advance.
Old 08-13-2015, 08:33 AM
1993_f350_2013's Avatar
1993_f350_2013
1993_f350_2013 is offline
Could you do a tremec 6 speed with a divorced t case?
Old 08-13-2015, 09:21 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
Why not a ZF?
Old 08-13-2015, 10:19 AM
DeereFord300's Avatar
DeereFord300
DeereFord300 is offline
Originally Posted by Freightrain
Why not a ZF?
Precisely
Old 08-13-2015, 10:26 AM
thompsj0784
I thought about running a t-5 with a divorced t-case, but I was concerned how it would hold up to towing or hauling in the event I needed it. I don't tow anything really right now but I haul stuff around quite a bit. I wanted to put a zf in the only problem is I live in Michigan and the closest one I can find is in Pennsylvania and I was still concerned on how it would hold up to 400-500 ft/lbs of torque.
Old 08-13-2015, 10:44 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
It was designed for that kind of torque: ZF 5 Speed Specs | ZF S5-42 & ZF S5-47
If you plan to use the truck as a truck the ZF-5 will be hard to beat. It is not a fast shifting trans. If you plan to treat the truck like a Mustang/hot rod then look for a car transmission like a T-5 or other Tremec variant.
Old 08-13-2015, 11:57 AM
Freightrain
Definitely DON'T want a T5. That won't put up with the weight of the truck PLUS the HP he plans to put through it. Only real choice is a TKO of some sorts.
I'd find a ZF. No sense in speed shifting a 4x4.
Old 08-16-2015, 10:40 PM
thompsj0784
Well zf it is I guess. How hard is it to convert a 2wd zf to 4wd I know you have to change the tail shaft, but are the parts to do it hard to find? I guess I know the whole trans has to come part, but has anyone paid someone to do it? I don't know if I have enough know how to attempt that one.
Old 08-17-2015, 09:36 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Zf5 is not going to be a good transmission for what it sounds like you want...the zf5 has only 3 acceleration gears.
First, what are you doing to achieve 400 whp with your 302?
2nd, the mazda will handle a mildly built 302 just fine, and is geared much more street friendly as it has 4 usable acceleration gears.
There are other trans options but let's start with how you are getting 400whp.
Old 08-18-2015, 09:32 AM
thompsj0784
I going to run an x-cam with .483 lift and aluminum probably performer heads, with forged piston. Still trying to figure those out because I want to keep it around a 10:1 compression ratio for when I put the turbo on and then run about 10 psi of boost with that. Naturally headers and I will run an intercooler and I'm thinking Water-Meth to keep everything a little cooler. I'm also doing a mass air flow conversion, I think a 65mm throttle body would be good and a Mega Squirt system to tie it all together.
Old 08-18-2015, 04:01 PM
bashby's Avatar
bashby
bashby is offline
I think I'd srart with a 351
Old 08-18-2015, 04:06 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
I could talk a lot about your engine plans but I'll stick to your trans...
NV5600 is what I'd run if money's not an issue. You can get an adapter for it to mate sbf. Will cost around 3k for an adapter and a used trans, plus driveshaft work.
If money is an issue then zf5 it is, just have to live with the poor gearing.
Old 08-18-2015, 04:30 PM
rla2005's Avatar
rla2005
rla2005 is offline
Same here
Kolby Haynes
06-03-2017 06:59 PM
Kenny Maness
05-01-2016 04:50 PM
headautomatica8
15
05-27-2012 02:21 PM
falcon5spd
12-24-2006 11:35 AM
Quick Reply: Manual Trans for 5.0 Build
