Needle bearing in hub.
The harder part will be getting the old one out.
I did mine recently. I used a punch to knock the old bearing out. A flathead will do the trick as well, just make sure you hammer on the edge of the bearing and not your hub assembly. Once out I used the old bearing and a block of wood to hammer the new bearing in. Make sure your axle stub is not worn down by your old bearing. This is a common culprit for blown hub seals, bearings, rattles and knocks.
1999-F150
06-03-2018 06:43 PM
