The building of "Babe the Blue Ox"
#766
If your pulling in the heat where your at, I wouldn't use the 203°. Years ago Jose it seems like everybody was jumping on the 203° band wagon, including me.
http://www.dieselsite.com/1994-19977...ionsystem.aspx
The link is for the coolant filter, I asked for the Billet Housing and the new RADIATOR HOSE # parts, that has to be used with that new billet housing, that is different from the OBS. thanks anyway.
I will say that I have seen a failed Tstat that failed closed. It happened to me while towing with the 3/4 ton Suburban I owned before getting the OBS. Also, I don't think it's the coolant temp that's a problem in and out itself, but it does cause the oil temperatures to be higher than desirable. I ran the 203* thermostat for about a month and that was the reason I got rid of it because my oil temps were through the roof and the 180 solved that.
#767
On my way home from RRE, I hit the "L" on the gauge and oil temp was up to 250. I pulled over and it immediately started dropping, then I went on. But I've got bigger fish frying, I don't have any go fast goodies besides DP, chip, and intake.
I don't think oil temp is a huge deal on these, but obviously water temp not far behind would be.
#768
#769
Glenn, don't pull yours. There is no way to seal it. The gasket depends on the Tstat to seal. I tried this too....no Bueno.
#771
Curious what Glenn comes up with here. I did not have a monitor on the truck to see EOT. but I had the same issue this past weekend when towing a few passes. There is something else going on. Usually when pump starts failing this is what I would expect, but I put in a brand new Alliant Power OE pump and FORD thermostat. I rarely see it too but I am starting to think my radiator is truly plugged up a bit or my coolant temp sensor is reading funny. I do not believe it’s the coolant temp sensor though as when I’m driving unloaded I’m anywhere between the N and R like it typically was. The truck always was at or a tad below N when cruising unloaded.
This weekend we pulled a couple 8-15 miles passes with the pedal to the floor in 4th/5th and the truck would steadily climb all the way to the L and seemed like it might have kept going. Def felt hot in the cab too. It never did this before. Would never climb over M. I only had about 8k behind the truck and have pulled 3 times that up much steeper grades in 2nd or 3rd gear only without it ever going over M. Going down the backside it would cool right back down, but just didn’t seem like it was cooling as efficiently as it had in the past. So besides a lower temp thermo, and or a new radiator. I’m not sure what else it could be.
I'm really curious what glen comes up with, as I was able to hit L on the gauge, and I do not want to do that again either. I know my oil was hot because I had a bit of spatter from my CCV on the trailer. Even when I towed heavy I never saw that.
So Glenn.... I am really curious to hear what you find out! Because I will be following suit!
#772
#773
Yeah Thomas, I talked with Clay at length about this whole temp thing. He said it won't really hurt anything other than shortening oil life. I was glad to hear that since I got mine up to 235-240 with the Napa 192 thermostat. With the 180 though, EOTs were never higher than 220 towing and that was really working it. I just wanted to see how it would behave and it was good.
Good to hear Byron but I would think that the Ford gray stuff would seal it? If not, a guy could gut the thermostat and just have the ring on top to help seal it. This would be my last, last resort.
I'm still going to order that 180°!
Darin, you might be right about the light and that's what I thought yesterday, I kept going. The gauge in the middle isn't to bad, higher then I've seen before on my other PSD's. Like Nike said, downhills it would cool right off and when it wanted to go above the middle of the gauge I could hear the roar of the clutch fan. But, when I got here and let it idle while I opened gates it didn't cool off, that bothers me! Of course there isn't any air movement doing that but it was in the mid 50°'s.
#774
#775
#776
#777
#779
Got a part number because I still have my box and did not measure before I put it in. But I made sure it was for a 96/97 and not a 95 short stem...never measured.... though
#780
