The building of "Babe the Blue Ox"
#106
#107
#108
This is epic. Should be a couple of good builds. Glenn I highly doubt you will max out your ones with two tunes. The stage two tunes should have a shorter injection time which won't allow the stage ones to empty. An 80% nozzle will require a lot almost have the injection time of a stock nozzle.
#109
That's for sure Byron! It still hasn't sank in yet, LOL
Thanks, I don't know what to think about it. It will be interesting what the other two turners say.
#110
I believe Travis would say its not enough fuel to spool the snail properly.
I know the smokier tow tune vs the dd and tow tune of the other guys...the smokier wins hands down except the trans gets overwhelmed lol
When im in the spooling range of the turbo(over about 1700) i dont really have egt issues.
Im only at very best pulling half what you pull tho. I have 3.55s and 285 tires wich slaughter my potential. If we upgrade campers down the line I will do 4.10s . im just not into long trips in clifford unloaded when i can be rockin the town car lol
#111
Yeah, Nate, but I'm not sure if we'll stay at your place or do something else. My brother-in-law has a pop-up, but I've never gotten him to let me use it even though I work on his junk all the time.
Edit: Heather got so excited last night when I told her what was going on, lol.
I sent the injectors to Jim and the turbo to James Barder today. I left a note in each box where to send them and when they call for payment I'll tell them to give me a tracking number. Aaron, tomorrow I'll get the up pipes, pedestal and drain plate and get them ready to send to you. Also tomorrow I'll switch wheels on the two trucks and get the air bags.
Today we did the final run to the salvation army and auction place with the last of the stuff. DONE DONE DONE, It doesn't really look like there could be much in the trailer but the one I took a picture of on the inside has a ledge on the side. I put boards across making shelfs and stacked stuff to the ceiling. When the mule hauled it several years ago I knew I had a load on. That thing was very, very heavy!!
Well boys, I've been back and forth with Glenn since this catastrophe happened and we spoke again not long ago. I'm happy to announce that we came to an agreement and the Mare WILL live again! The plan as of now, is to put my motor/trans and interior into the Mare. Oh along with a fresh painted frame I have at the hillbillys and a D60 install! None of the transformation will start until spring at the earliest, but the ideas have already been swirling. It sickens me that this had to happen to our resident Santa, but rest assured, I'll take good care of her!
#112
Ohhh Todd's purchase is official!!!
haha it must be the weekend for buying.... because I just heard last night around 6 that the sellers accepted my offer! Assuming inspection goes well tomorrow night I will be the owner of my own 2 acres with a 3 car garage come September 18th!
Which means I more than likely won't be able to make this... I could be insane and try to prep for moving AND make a 16 hour weekend trip, but more than likely not. lol
Sorry all! I know Glenn will be taken care of.
#113
#115
Secondly, you're a young man. Buck up and make the trip!
#116
I hate to ask the possibly stupid question, but I'm going to ask anyways... why not swap engines? Why not take the engine from the old truck and put it in the blue truck? Doing head studs and valve springs alone will take longer than an engine swap takes.. since there is a time crunch and what I'm reading is a hell of a lot of work in that amount of time. You would save a lot of time swapping engines and doing any new part installs on the engine before installing it in the truck.
#118
#119
#120
If this is starting to look like to much work we can always change our minds. I would rather have the low mileage motor done but I don't expect a bunch of guys to do all this work either based on what I want.
OK fellas...... I emailed ARP tech support and asked if the head studs can be re-used.
Folowing is the answer I received today.
"Brian,
The studs can be reused as long as they haven’t been over torqued or damaged in some way.
Best regards,
Alan Nichols
Sales & Technical"
"Brian,
Best regards,
Alan Nichols
Sales & Technical"
Thanks for that Brian!
JP & Thomas, you are both right but see above my answer to Travis.
Nate, I always wanted a motor to tear apart and rebuild but will probably never get to it.
