The building of "Babe the Blue Ox"
#76
#79
I sent the injectors to Jim and the turbo to James Barder today. I left a note in each box where to send them and when they call for payment I'll tell them to give me a tracking number. Aaron, tomorrow I'll get the up pipes, pedestal and drain plate and get them ready to send to you. Also tomorrow I'll switch wheels on the two trucks and get the air bags.
Today we did the final run to the salvation army and auction place with the last of the stuff. DONE DONE DONE, It doesn't really look like there could be much in the trailer but the one I took a picture of on the inside has a ledge on the side. I put boards across making shelfs and stacked stuff to the ceiling. When the mule hauled it several years ago I knew I had a load on. That thing was very, very heavy!!
#81
#83
#85
Used a bfh, tomorrow I'll take my air chisel. Ya, no fun at all crawling around on the ground. Got one air bag off! LOL
Not only stuck together, the inside rim was stuck to the brake drum too. I know that's common but I'm glad I wasn't on the side of the road trying to change a flat!
#86
Yeah trying to get one of those off on the side of the road would have been no bueno.
#87
Get some anti seize when you put them back on (around the hub and a little between the two wheels) it makes it a little easier next time. A bfh is what I use just hit the tire and turn hit and turn till she comes loss.
#89
#90
Thanks Mike, hope your getting healed up fine. Darin says he reuses them all the time in his race engines. This is from ARP website:
Are ARP bolts and studs re-usable?
Yes. As long as the fasteners have been installed and torqued correctly, and show no visible signs of damage, they can be re-used. If they show any signs of thread galling or corrosion, they should be replaced. In the case of rod bolts, if any of them have taken a permanent set and have stretched by .001” or longer, you should replace them immediately. See page 29 in the catalog for more detailed information on this critical measurement.
