1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
HELP with coil pack and plugs 2009 250
Old 08-04-2015, 06:16 PM
Tommy B405's Avatar
Tommy B405
Tommy B405 is offline
i have a 2009 f 250 5.4 v8 trition motor my coil packs are slowly failing i want to replace all 8 of them can someone tell me which coils and plugs im going to need i guess ill replace the plugs also ,how are the accel coil packs and ngk plugs i dont mind paying alittle more for better stuff thanks in advance tom
Old 08-05-2015, 07:38 AM
DavidB's Avatar
DavidB
DavidB is offline
Coils DO NOT "slowly fail". Most coils fail due to some other fault such as bad plugs or shorted boots. Coils can be tested for proper operation. Replacing coils "on general principle" or due to age is a WASTE OF MONEY.
Do a proper tune-up including plugs, filters, pcv , check all vacuum lines, wiring connections (especially grounds), etc. Then, if you still have a problem, you can test the coils and replace any that may be bad.
You cannot replace a factory coil with "a better one" or one that will give improved performance.
I would not use NGK plugs. You cannot put a "better" plug into your Triton engine than the correct Motorcraft plug. The correct Autolite plugs are also good. I would not recommend anything else. Especially NOT NGK.
F0rdE$cape
Escape & Escape Hybrid
04-15-2015 10:38 PM
redman024
1997 - 2003 F150
06-24-2009 09:50 AM
Methodical_1
1997-2006 Expedition & Navigator
03-31-2009 07:00 AM
waltjmat
07-09-2008 09:03 PM
rsavage
02-02-2004 06:56 PM
Quick Reply: HELP with coil pack and plugs 2009 250
