Lope after transmission swap
Oh - another question for the OP - is a chip/progranner/tuner in the picture?
There is no ECM. The PCM runs the engine (and, on automatic-equipped trucks, the transmission). Look at the harness connector on the PCM on the under-hood side for a four-character (three letters, one number) code. You may need an inspection mirror. If that label is unreadable, remove the nuts holding the parking brake pedal/release assembly to the side wall of the cab, and pull the assembly away from the cab wall (no need to disconnect it). The label on the in-cab end of the PCM should have that code as well.
Is this a California truck, by any chance?
I was posting on a thread "manual to auto tranny swap" I was under the impression that the IDM and PCM had to be changed together, but after we discussed it awhile, and doing some research we came to the conclusion that the IDM's are all interchangeable, though send a different amount of volts.
I assume the different voltage will open the injectors farther the higher the volts, but I dont know how big of a deal that would be for him unless it was a lower voltage IDM starving it for fuel???
Sorry about the hijack of this, but I would like to be better suited to answer questions like these.
