6.4 injector replacement
I did find a video by srmastertech. Torque the injector hold downs to 25 ft lbs. High pressure lines are one time use. Install lines hand tight, then torque to 9 ftlbs, then turn the nut 60 degrees ( one flat ). When you first remove the hp line from the injector catch the fuel in a small plastic container. If you see any metallic debris you have a pump failure on your hands.
I did find a video by srmastertech. Torque the injector hold downs to 25 ft lbs. High pressure lines are one time use. Install lines hand tight, then torque to 28 ftlbs, then turn the nut 60 degrees ( one flat ). When you first remove the hp line from the injector catch the fuel in a small plastic container. If you see any metallic debris you have a pump failure on your hands.
petepetersen
27
07-18-2017 12:58 PM
joe f350
10-18-2011 10:33 AM
Coccyx
08-18-2010 06:49 PM
