Sponsored by: Halo Lifts
Tow/Haul mode
Old 08-01-2015, 08:13 AM
rednck21's Avatar
rednck21
rednck21 is offline
Tow/Haul mode
Has anyone else noticed the really aggressive downshifting in tow/haul mode? Mine will downshift to 4000 and even as high as 5000rpm's when I get on the brakes. What frustrates me the most about it is going down a hill it will start downshifting without tapping the brakes when my 2011 ecoboost would not downshift until you tapped the brakes once. It was nice to be able to coast down a long hill! The downshifting on the 2011 was much less aggressive, too. I'm thinking these new truck are like this because of the increased trailer capacity...
Old 08-01-2015, 08:24 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Yes, I've noticed it. We just spent 3 days driving Arkansas mountain roads and I used tow/haul extensively for the quicker downshifting on both uphill and down. But, the compression-braking is too aggressive in my opinion, so I'll try Sport or Manual modes in future. I saw 4000 RPM in several instances, like coming up to a downhill stop, and I didn't like all the noise nor the wear and tear on the equipment.
Old 08-02-2015, 11:54 AM
rednck21's Avatar
rednck21
rednck21 is offline
Yes I agree. I don't mind a little downshifting, but 4k+ is just too much for me to handle. Even if the downhill downshifting was activated by tapping the brakes it would be much better. Speed up maybe 5mph with your foot off the gas and it starts! Id much rather do an extra brake job or two over the life of ownership than replace drivetrain components...
Old 08-02-2015, 12:22 PM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
Add me to the choir. We live in the mountains, and have to go to town (in the flats) for many errands, projects. So we are always going up, or going down, and I'm developing habits to compensate for the truck's inability to deal with the situation. I pretty much go to manual mode and do it myself. The truck seems to always want to be ~~ 1100 rpm on the uphill (too low), and too many RPM on the downhill. The 3.5L EB is a great engine, but when going downhill with close to zero fuel going in, I suspect there is not enough compression to afford an adequate compression brake.
Old 08-02-2015, 01:14 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I'll try manual next time coming down. Tow/Haul helps a bunch going uphill though. Yes, 1100 RPM is just too low for climbing as it takes too much throttle and eventually a downshift. Why not do it earlier and stay out of the throttle a bit more.
Old 08-03-2015, 10:22 AM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
I find that I'm running about 1500-2000 RPM in 3rd gear a lot of the way. There are several switchbacks that require me to go to 2nd, and a few straightaways that allow up to 4th. However, keeping the RPM above 1500 is the general rule (for me on our mountain climb). As usual YMMV.
Old 08-07-2015, 11:01 AM
kenttrudiw's Avatar
kenttrudiw
kenttrudiw is offline
Yes, it is crazy aggressive. The first time it happened, it really scared me. I thought that a 18 wheeler was running me over because the engine noise was so loud.... It was really weird, how it almost slams you to the window slowing down,
But, I really, really like it once I got used to it. I towed in light traffic with out T/H on. I really had to press hard on the brakes to stop my 7,000 lb boat before I ran into the guy in front. I turned T/H back on, and it made a huge difference in braking. I don't tow without having this button on anymore.
Crazy, I have just reached 3,000 miles on my Truck. I have towed my Four Winns boat almost 1,600 miles already, with another 400 miles coming up this weekend. This is why I jumped from the Expedition to the F-150, and I am very happy I did!
Old 08-07-2015, 11:08 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I like the way T/H shifts - except for the compression braking part. So, I tried Sport today and was running 67 down the highway in 5th. Not 6th. I wish there was a way to tune T/H and/or Sport to my preferences.
Old 08-08-2015, 09:38 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
Your wish is granted. Get a custom tune.
Old 08-09-2015, 06:52 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
My understanding is that the truck records when I do that, and it can void my warranty. Thanks, but no thanks.
Old 08-09-2015, 02:58 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
Then you'll have to keep dreaming.
Old 08-11-2015, 03:31 PM
jrank's Avatar
jrank
jrank is offline
I noticed on mine today when in in tow haul mode it downshifts really hard from 5th to 4th. Im not talking high rpms. It feels like its slaming into 4th. I don't like it.
Old 08-18-2015, 01:49 PM
kenttrudiw's Avatar
kenttrudiw
I had an issue with my boat trailer. (Boat is about 6500 - 6800 lbs with load). I found out my trailer had a broken brake line, so I had no trailer brakes my last 1,000 miles or so towing the boat. I had to use T/H to stop my Truck, otherwise I really had to push on the brake petal to get this thing stopped.
So I can say from a bad experience, these Trucks can stop an almost 7,000 lbs trailer! What really is disappointing, is that the Truck really stopped very well, and I could not really tell that my trailer had no brakes at all. If I did not active T/H, then I knew my brakes were taxed, but not like what you would have thought. Bottom line, these Trucks have a lot of braking behind them, to stop your load. I am very confident with this braking ability that Ford has built into them.
Old 08-18-2015, 05:12 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
It does have 13.8" brakes.... bigger than C6 Corvette.
Old 08-19-2015, 01:43 PM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
Yahhhh. That has been a minor issue for us. Not a problem, just not used to brakes working that, um, positively...
Quick Reply: Tow/Haul mode
