No Start in Park, No Start in Neutral, New MLPS.
I have been having issues with my 89 IDI with an E4OD for the last few months. Kept having to mess with the shifter while in park to get it to spin the starter. replaced the MLPS, with a BWD branded one. already had the new connector installed. Lined up the marks, Worked for a day, then had the same issues again. It even sometimes will not start in neutral, I've had to pop the hood and jumper the starter relay trigger terminal to get it to spin. I'm all for fixing something the correct way, can anyone give me advice on what I'm doing wrong or what else it could be?
on
with the truck in N,hold the key to start while shifting upwards and downwards.will the starter then spin? if so,the range sensor (mlps) isn't adjusted correctly.
if it doesn't,then suspect your ignition switch.you can test to see if there is power going to the small terminal on the fender mounted solenoid when you turn the key to start,using a test light.
Last edited by FORDF250HDXLT; 07-28-2015 at 08:52 PM. Reason: start,not run position.my bad.
New MLPS... NO Crank, No Start... and hearing clicking sound
Hi there...
Currently new to the platform and pretty much have the same issue with my 1994 Ford F150 XLT Lighting; short story, I thought I was doing a simple replacement with neutral safety switch or (MLPS) sensor, had taken the connector off and while I was attempting to screw the lever shifter, it moved out of place and I quickly moved it back. I also didn't know that I was suppose to have the car in neutral (it was in park when I started the whole process)… so now, changed the safety switch; truck won't start even I move it to park and go down every gear, replaced the shift linkage cable and replaced my starter with a new one (under warranty) and also hearing a click sound after I attempt to start truck... and now I am stumped and pretty frustrated... any thoughts on the next step?
Received 3,108 Likes
on
Jose Vazquez
07-01-2019 01:16 PM
bigoltruck
03-16-2013 01:03 PM
tw
13
01-27-2013 08:37 PM
