pre-trip must do's
pre-trip must do's
So I've had the ex for a few months now - no major problems. Its got 273,000 on it and we're preparing for a cross contry journey. We'll be headed east from Nevada, up throught the bad-lands area, and then to Michigan and back again. Grand total should be around 6,000 miles +/- a bit.
I've done the 'regular' stuff:
Fuel filter
Oil
Oil Filter
Tires checked (including spare)
Air Filter
Grease steering parts
Checked the batteries
Had the A/C serviced
Edit - also tore down, lubed and inspected brakes
Being my first ex and my first diesel I'm wondering if there is anything else I should be checking/servicing before I go?
Fuel filter
Oil
Oil Filter
Air Filter
Some other ideas:
Flush brake fluid,
Flush power steering fluid
Flush transmission fluid
Check steering damper
Replace f/r differential fluids
Replace transfer case fluid
Flush radiator, check all hoses (bring spares)
Check unit bearings
Check ball joints
Check all 4 steering tie rods
Check serpentine belt (bring spare)
Bring a well stocked tool kit.
Carry 5 gals of water.
Flush brake fluid,
Check unit bearings
Check ball joints
To go along with Matt....make sure you have a 10 mm socket with an extension to be able to change the cps out should it cause you problems....a lot of guys on here now carry that one specifically....it's in my door pocket after having to have Razzi bail me out on the side of the road a few months back
on
I do not have anything to really add to the list above of things to get done but make sure in your tool kit you have the allen key size to drain the water separator that is along the frame rail under the driver side door. I can not remember the exact size off the top of my head but having a whole key set is a good idea.
When are you making this trip? We may end up crossing each other on the road.
<strike>Flush brake fluid
Flush power steering fluid</strike>
<strike>Check steering damper</Strike>
<strike>Flush radiator, check all hoses</Strike> (bring spares)
<strike>Check unit bearings
Check ball joints
Bring a well stocked tool kit.</strike>
<strike>CPS
payoff credit card</strike>
Grease Unit bearings
So I actually did a lot of the recommended things I'd just forgotten when I made my list. I never travel without tools, but I haven't built my 'trip bag' yet so I left that one on the list.
TwitchyLeprechaun - we are leaving here later this week and spending 1 week in the custer state park area of SD, then continuing on to michigan. Where are you headed?
Check ball joints
<strike>CPS
For the spare radiator hoses, snag one for a dual alternator setup. The upper house is routed behind the belt instead of the stock one that goes through it, making belt changes in the future far easier and less messy.
For the differential fluid, make sure you verify if you have the limited slip or not. If you do, you'll need some friction modifier in addition to gear oil.
Our group is planning to spend a day or two in sturgis as well. That is the primary reason for our timing and destinations. I've never been, my Dad has gone several times (including the 50th anniversary) and wanted to go this year again for the 75th anniversary. Not sure what to expect, but looking forward to it!
What do you ride?
What do you ride?
Under Valve Cover Harness (UVCH) can kill a 7.3 without warning. Check to see if previous owner fixed it. If not, get it done ASAP. You can get the clips at Ford or the updated wiring harness.
Don't rely on battery light to come on when alternator dies. Mine died when waiting at a stop light, blocking traffic. This was my worst fear on long trips. I paid the price for procrastination.
I'll second this one, I've done both under valve cover harnesses recently (Summer 2013-passenger side, February 2015-drivers side). The first one left me stranded in the driveway, but the second one left me stranded on the highway.
Alternator dying won't kill a 7.3, it doesn't need the batteries to keep running. The rest of the dashboard will light up like a Christmas tree up until the batteries are totally flat, but the truck keeps running. My alternator died in the middle of nowhere in Nevada last year while moving back to Texas, truck made it another 13 miles with no issues. Batteries were toast, but it got me somewhere safe and with a population higher than 9 people.
The UVCH is a great suggestion, mine almost screwed me but luckily it didn't fully unseat. I went with the 50¢ mod over the clips, primarily because the PO had done the clips and one still worked its way out. Now I just run a bead of super glue around the connector in addition to the quarter trick.
Moral of the story, replace or upgrade your alternator. Local driving is no big deal. But when you are far away from home or in the middle of nowhere, it is an inconvenience and expensive.
Op, when was water pump changed? If it has original pump, then it's time to get a new one. Especially when you have a 6000 mile trip planned.
