Dimmer?
OK, so I guess any of the instrument/door plugs should be able to be tapped into?
I have a couple of auxiliary switches I want to install for low current items (2.5-5A) and don't want to tie up my factory auxiliary switches...but the indicator LEDs are bright as hell....they're also dimmer capable.
I don't think the lights on the up fitter switches dim with the dimmer rocker? But that's a good wire to know about, thanks for that info mpd.
So, you're setting up a slave circuit panel and it has power from up fitter, then, the lights on the switches themselves will be powered by a tap from a dome light? I get it now. I can't think of anywhere inside the cab where I would steal power from for those switch lights. Too bad there's not a light in the door or in the footwell.
I might be a little confused in my old age, activation, illumination or both? LOL.
From the 2013 wiring diagram the VT-GY wire from F12 and controlled by a FET in the BCM is for to light up the labels on the upfitter switches and the lights on the end of the upfitter switches are power from the load side of the switch you have turned on and don’t dim.
I used this wired to light up the cupholder slash ashtray with strip lighting in my 2008 (I have no console).
I guess it depends if the switches he has can be wired with the light having separate wire connections, he did say his can dim. For example a DPSTswitch where one set of contacts in the switch are to turn on the light? They are available.
Sorry if I'm still not getting it.
You need switches that have Dependent/Independent illumination/activation to your configuration.
Dependent: Turn the switch On and its pilot light comes on. Turn the switch Off and its pilot light goes off.
Independent: The pilot light onthe switch is independent of the On-Off status of its switch, and is controlled by a separate switch that you will need to purchase. Typically the separate switch controls the illumination of a bank of switches that have independent illumination. This can be a useful feature when you need to indicate the location of a bank of switches in a dimly-lit cab.
I’ve had them on my boats and I believe that they are called Carling Style Rocker switches for boats/Auto.We use them all the time at work, I will look when I get back from vacation.
69supercj
07-09-2015 06:56 PM
amer28
1983 - 2012 Ranger & B-Series
03-03-2012 07:58 AM
wizzy214
01-29-2012 06:02 AM
