Valve cover is cracked in my 2001 Escape
Old 07-26-2015, 05:02 PM
Jaybird68's Avatar
Jaybird68
Jaybird68 is offline
Has anyone repaired a crack in a valve cover as opposed to buying a new cover? If so, what did you use to fill the crack annd was it successful?
Old 12-19-2015, 10:32 AM
78 PEB's Avatar
78 PEB
78 PEB is offline
No experience trying to repair one but Im sure one from a wrecking yard wouldn't be over $20. If you do try to repair it, I'd "V" the crack with a grinder and then clean it up good with some brake cleaner. Also rough up the area around the crack with some course sandpaper to allow the JB Weld or what ever you use to adhere. Honestly by the time you pull the valve cover and go buy all the stuff to "try" and repair it.........You'd be better off just getting a good one from a junk yard......Just my 2 cents worth
tyrantsparky
04-08-2013 10:07 PM
ymcaman23
05-15-2011 08:52 PM
troys68
04-29-2002 10:03 AM
Quick Reply: Valve cover is cracked in my 2001 Escape
