brake noise 2015 f 250
I have not noticed it. What exactly are you doing at start up, and I can see of mine replicates it. Is your 6.2 or 6.7?
If I cant, either find another dealer, or get them to prove it with one on the lot.
level ground, sorry i should of mentioned i have a 2.5 block lift kit front and rear 295x70x17r nitto terra grappler g2 tires.lift kit guy said its ford brakes ford said normal,tomorrow its going to a independent technician full inspection brakes and suspension,thought if its a brake problem u guys have heard of it.
Mine has had it since day 1. They told me it's normal too. Just overnight rust buildup is what the Ford guy said more or less. And that other vehicles with the same brakes have it too. Also said to expect it to be worst in the cold. I wonder if someone living in the desert would get this too?
Mine also quiets down after a few stops.
told me likewise,i live on a dirt road neighbors don't like dust on their Cadillac's, county sprays chloride that chit mixed with sand may make it worse,oh im embarrassed to pull out of the garage when friends are with me. always washing inside wheel wells constant maintenance on my vehicles.....thanks will keep u all up to date.
Wrace
1999 to 2016 Super Duty
02-12-2017 07:28 AM
