Suspension Lift for 1979 F-250
Alright, I'm struggling here. I realllllyyyy want to lift my truck. However, I don't want a 4" or 6" lift. Have you guys ever seen a 2" suspension lift for 79 250? I can't find one anywhere.... I don't want to jack the thing way up. But I'd definitely like it to sit a little higher so I can get some bigger tires on it. I just got a set of 265/70R17's today and I'm just not digging the height or width. Too skinny and not tall enough. While I'm at it, what's the biggest set of tires you guys have fit on your non-lifted without any rubbing?
There are lots of options, but here is one. http://www.summitracing.com/search/y...rder=Ascending
OK, When I bought the truck it had the 35's. It had stock suspension with flat to slightly negative arch in the front. It had the stock nose down stance.
The tires rubbed slightly on a sharp turn
Here's the back (still stock suspension) 23" from wheel well arch to center of hub. About 6" clearance above tire.
Here's front with added leaf. 22" from arch to hub center. 5" clearance. No rubbing issues. Again, I don't take it rock crawling..........
I have a 4" and 35s on my F-250.
This picture is with a 4" lift in the front and 2" in the rear. It's almost perfectly level
I later ditched the 2" lift block and went with lift springs for the rear. This lifted the rear another couple inches. I personally like the rake a little better than the leveled look.
Here's a 4" lift all the way around (all spring) and on the same 35s.
I hope that helps!
I hope that helps!
x_FordMan_x
02-21-2002 08:55 PM
