cylinder #1 missfire.
Received 3,110 Likes
on
99 4.6, 73,000 miles. in a (crown vic)
i swapped coils with cylinder #2, miss stayed on #1. there is aslo new connectors and o-rings on the injectors. all this started when the intake broke on the coolant side wetting out #1,2,and 3 cylinders shorting out the coils. put a new intake and 3 coils on 400 miles ago, and now i just lost #2. other than a bad plug, any ideas?
So I'll be following this thread. Sorry I can't help.
on
i have not been able to get back to it between work and the rain. i am going to try swapping spark plugs between #1 and #2 like i did with the coils. if the miss goes to #2 i will know it is the plug, if it stays in #1 then it will have ot be electrical or in the computer.
i am hoping something fouled the plug when the intake was swapped.
on
on
on
finally got the new injector delivered yesterday after it was sent all over the country... twice.
put it in this morning only to find there was nothing wrong with the old injector beside a bent negative pin. it seems the dumb *** that put the new injector connectors on must have put the connector on the injector crooked and bent the pin, then not notice the pin was bent when i moved the injector. i saw it as i was putting it in the box to throw it away.
