Source for oil psi switch terminal???
Does anyone know where I can find a wire end that will fit this style oil pressure switch connection on a 1966 F100; it is the switch for the dummy light in the dash with 352 engine. Wire end was not present and stripped wire was wrapped around the connection. Tried a variety of auto parts stores and the usual repop suspects hoping someone carried one with a stud connection rather than as depicted -- no luck.
Ok,
Thanks guys. I guess I have the wrong generic spade terminals. The ones I tried look like a closed staple when you look into the end and those do not work. That was the same generic style all the places I tried carried.
RANT - when the hell did every little thing you want to look at in a hardware or auto parts store transition to hermetically sealed little packages so you could not put your %&*$ hands on it and see if it works. I remember years ago such things were loose in bins and one could touch and check before purchasing.
I did see this listing below for a T-bird on Mac's; got to order a few things from them anyway so may just throw on the order.
Ford - Ford Thunderbird Oil Pressure Sending Unit To Cowl Wire, PVC Wire, 28 Long, 1956-57 - Macs Auto Parts
Look at any 1974/90's FoMoCo vehicle in a junkyard. Take side/wire cutters with you, as this wire was only furnished as part of the engine gauge feed harness.
The correct switch is: B6AZ-9278-B (Motorcraft SW-667) which has a threaded stud on the top of it. It was used 1956/73 on all FoMoCo vehicles with a warning lamp.
Go to any chain auto parts store, tell the parts cluck you want an oil warning (idiot) lamp switch for a 1965 non GT Mustang.
FoMoCo obsoleted this switch over 20 years ago: CARPENTER NOS OBSOLETE PARTS in Concord NC has 11 = 800-476-9653 / GREEN SALES CO. in Cincinnati OH has 17 = 800-543-4959.
If you call one/both of these sources, make sure the switch has the stud on it.
This is odd, then. Same part number but not a threaded top, either.
Same part number, but it's probably mis-boxed. This is why I said if buying NOS, make sure it has the stud on it.
1956 1965 1966 1968 Ford Switch Clip on Top B6AZ 9278 SW 667 Mustang Cougar | eBay
Knowing you, you'll probably say this is the wrong oil filter adapter, so I'm gonna beat you to it.
This pic was originally in the 1949/59 Ford Passenger Car Parts Catalog. Ford recycled it, changed the captions.
As usual; post a question here and get a wealth of information!!
Bill,
does that mean the switch lead referenced in post 5 that Mac's has listed for 56-57 T-Bird is bogus? Or maybe since the stud connector switch is obsolete the repro lead is equipped with the spade terminal since the replacement switch available takes that connection?
Bill,
Thanks Mike,
I have a mechanical oil pressure gauge installed because I don't trust idiot lights (or electrical gauges for that matter so have mechanical water temp too) - by the time it comes on your already looking at a lot of $$$$ in most cases. I do want the idiot light to work though just cause it is in the dash cluster. On the road for pipeline work for a month or more and will try the suggestions received when I get home. Got the engine and tranny in last week and hope to get running next time I am home.
If the optional oil pressure gauge is present, so is the warning lamp.
When both the oil pressure gauge and warning lamp senders are present, a fitting is required for them to thread into.
There are TWO different types of fittings:
C1TZ-9B339-A = 1965/66 F100/250 352 4WD - 1965/66 F350 352 / 1967 F250 352 4WD
C5TZ-9B339-B = 1965/67 F100/250 2WD/4WD & F350 240/300 I-6 / 1965/67 F100/250 2WD 352.
And btw: E4ZZ-9278-A (replaced B7T-9278-B ~ C7ZZ-9278-A ~ C9ZZ-9278-A) .. Oil Pressure Gauge Sending Unit (Motorcraft SW-667) / Available from Ford
Applications: Myriad 1960's-1990's FoMoCo vehicles. *Does this 1984 replacement have the threaded stud for the wire...or not?
