Cavitation or head gasket? Block sealer?
I have a 7.3 idi building pressure in radiator. Got it tore down head gaskets were thin and fell apart in our hands with cracks essentially. Cylinders look clean a little bit of piston ridge. Truck ran strong no mixing fluids. Hard to start but also found out tearing it down it had a mix of champion and auto lite glow plugs.. My uncle has done engine work for years and says even if it's cavitation bars leaks would fix that right up.
Received 3,112 Likes
on
nope. if the cylinder walls are cavitated the only thing that will fix them is a sleeve. cavitation is coolant in the cylinders, not pressurized coolant system. that is head gaskets or cracked heads.
i woul have the heads magnafluxed to look for cracks, and put new head gaskets on if the heads are good.
and make sure you only use motorcraft ZD-9 glow plugs when you put it back together.
I've always used beru on my 6.9 I was always told they were best.
Are fel pro a good gasket? Also is the metal piece under intake part of the gasket?
Is a new starter something I should go ahead and do? Somebody mentioned I think DB electric or something as having a great one. Mine is Ok definitely not like a cummins as some have described.
on
i had a DB starter in my 88. it only lasted a year and left me stranded in a fuel station. started up fine in the morning, 3 hours later i shut it off to fuel up and deader than a hammer against a steel block.
i had one that was rebuilt by a local shop on the shelf at home, and put that in 6 years ago.
on
It looks pretty clean probably has 161 thousand I doubt 261 it just looks to clean. It's a farm truck longest it has ever sat was 2 weeks it turned over fine and fired up in 7-8 seconds of cranking. It was originally an ambulance so maintenence should have been good. I'm putting the motor in a f250 so I have 4x4. It had regular antifreeze but I was told as long as you change it every 2 years it won't become acidic.
on
a good hydrocarbon sniffer can help in diagnosing coolant related problems. if you do a pressure test of the cooling system with glows removed then crank it could still be a head gasket if coolant leaks into a cylinder you wont know for sure till you take it apart.. stop leak is never the right tool...
on
To test the head gaskets and for cavitation.
First you need shop air pressure and an air hose adapter to thread into the glow plug hole.
So the next step, remove all of the glow plugs.
Remove the rocker covers on both heads.
Loosen the rockers on both heads so the valves stay closed.
Now start at one of the cylinders, screw the air hose adapter into the glow plug hole.
Remove the radaitor filler cap and fill the radiator completely full.
Now apply shop air pressure to that cylinder.
CAUTION WHEN YOU APPLY AIR PRESSURE THE ENGINE WILL TURN OVER UNTILL THAT PISTON IS AT BDC.
Watch for bubbles in the radiator, coolant overflow from the open cap, the sound of air leaking through the intake or exhaust.
Repete for each cyinder, make notes of the results for each cylinder as you go.
Bubbles or coolant overflowing from the radiator indicate either a blown head gasket, cracked block or cavitated cylinder wall on that cylinder.
Air leaking sound from the intake, leaking intake valve on that cylinder.
Air leaking from the exhaust, leaking exhaust valve on that cylinder.
When I say shop air, really any air compressor capable of over 100 PSI would do.
Higher air pressure makes the test faster and more obvious.
like Tom said above,you need to properly maintain the SCA levels (checking with a test strip every other oil change is a good rule of thumb) and you must use a low silicate coolant.
