Help hooking up aftermarket speedo on 71 f250 with zf5 swap
Bought my truck about a year ago with no gauges in it at all.
Sucessfully hooked up tach,oil,and temp gauges
Cant figure out how to hookup speedo
Truck has a D9TE-ab block from a town car
has a zf5 5 speed out of a 90's f350 i think
Read somewhere that the trucks with factory zf5's got speedo reading from rear end
My truck has the stock dana 60 from 71 so that wont work?
It doesnt get the reading from the side of the trans?
How to hookup aftermarket speedo?
Thanks Kris
Thanks Kris
The post-91 trucks had an electronic speedo connected to the rear end no matter what engine/trans, and the pre-92 trucks had the manual speedo from the trans if 2wd or from the t case if 4wd. you'll have to find out what yr truck the trans came from, your kinda out of luck if it's a later trans
This won't necessarily be the least expensive route to get a functional speedometer, and other functional in dash gauges but, if you get an F500-up big truck instrument cluster bezel, you can install full instrumentation in it, along with a GPS controlled speedometer.
The GPS speedometer won't require figuring out any drive cables to the speedometer and no wiring a VSS (Vehicle Speed Sensor) to it.
Just an example of a GPS speedometer.
GPS Speedometers > Gauges Only > Revolution
Example of an old Bumpside F600 instrument cluster that the modern gauges can be installed in.
F500-up instrument bezel with Speed Hut gauges. --this bezel from a '73-'79 Dentside big truck.
52M37
04-11-2017 06:07 PM
automaticlee
02-19-2017 01:39 PM
Softtopper
02-28-2008 06:45 PM
