Rag joint? Shifter bushings?
Old 07-04-2015, 01:29 PM
rockpile's Avatar
rockpile
rockpile is offline
I just picked up 1970 f100 260cu i6 three on the tree 2wd. I'm having trouble finding a rag joint and shift linkage bushings. Are there parts still out there? Is there a fix using other none factory parts? The truck runs great just a little slopy.
Old 07-04-2015, 02:19 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Old 07-04-2015, 03:07 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by rockpile
I just picked up 1970 F100 240 I-6 three on the tree 2wd. I'm having trouble finding a rag joint and shift linkage bushings.
C9UZ-3A525-A (replaced C9TZ-3A525-B & D3TZ-3A525-A) .. Steering Coupler (aka rag joint) / Obsolete
Applications: 1969/74 F100/250 2WD & F350 with or without P/S / 1969/74 Econoline / 1975 F100/250 2WD & F350 without P/S
No Ford dealer or obsolete parts vendor has any. Available from Dorman Products, sold by auto parts stores.
Bottom of the steering column underneath the hood are the two manual control selector levers that the shift rods from the trans attach to.
In each lever is a rubber bushing & insulator. The bushings age crack, the shift lever has play and/or binds up.
C5TZ-7343-A .. Bushing & Insulator Kit / Obsolete
Applications: 1965/72 F100/250 2WD with 3 M/T
SUSANVILLE FORD in Susanville CA has 1 = 530-257-2137.
TOWER MOTOR CO. in Coos Bay OR has 2 = 541-269-5062.
GREEN SALES CO. in Cincinnati OH has 12 = 800-543-4959.
PARTS INTERNATIONAL in Farmers Branch TX has 22 = 888-727-0418.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 713 = 800-476-9653.
Old 07-05-2015, 01:45 AM
rockpile's Avatar
rockpile
rockpile is offline
Great info. I'll jump on that in the morning. Or Monday because nothing will be open tomorrow. Happy fourth🙌
Old 07-05-2015, 02:22 PM
qman's Avatar
qman
qman is offline
anybody ever use one of these polyurethane pieces for the rag joint fix? What's so special about polyurethane?
Amazon.com: Ingalls Engineering 84952 Flex Coupling Disc: Automotive Amazon.com: Ingalls Engineering 84952 Flex Coupling Disc: Automotive
Old 07-05-2015, 03:24 PM
NumberDummy
Rag joint, so called because the rubber section was made of bias ply tire carcass that has cloth threads in it.
Auto parts stores sell a replacement disc, but R & R'ing it can be a real b!tch.
Old 07-05-2015, 05:16 PM
rockpile's Avatar
rockpile
rockpile is offline
Is the urathane piece an insert or a complete part?
Old 07-05-2015, 05:34 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
the rag joints original purpose was to break away in case of a head on accident . The older Fords pre 67 had the steering shaft one solid piece out of the steering box , this would impale the driver in a head on accident .
so I would stick with the original design . you can buy the rag joint kit at most auto parts stores in the Help section .
Old 07-05-2015, 09:30 PM
spdcat72's Avatar
spdcat72
spdcat72 is offline
I'm not sure how the rag joint would allow the steering shaft to break free in a head on collision? The column flange sits almost on top of the steering box and has pins that keep it aligned. I thought the purpose of the rag joint was to insulate the steering wheel from road vibrations and such.
Old 07-05-2015, 10:15 PM
rockpile's Avatar
rockpile
rockpile is offline
It is definitely a primitive steering damper. Not sure about colapsable shafts in the that old of truck.
Old 07-06-2015, 06:35 AM
NumberDummy
Originally Posted by MIKES 68 F100
the rag joints original purpose was to break away in case of a head on accident.
The older Fords pre 65 had the steering shaft one solid piece out of the steering box, this would impale the driver in a head on accident.
Steering coupler (rag joint) introduced in 1965 F100/250 2WD, it's the same for 1966 F100/250 2WD before serial number 900,001 (C5TZ-3A525-A - larger locating pin is .41" O.D.).
1966 F100/250 2WD from serial number 900,001, 1967/68 F100/250 2WD use a different steering coupler (C6TZ-3A525-A - larger locating pin is .56" O.D.).
The steering coupler bolts to the flange of the steering shaft, its splined end slides onto the splines of steering gear box' input shaft, a thru bolt and nut retains it in place.
Considering how the coupler is attached, how can it break away in an accident? The 4WD's did not use a steering coupler (rag joint) until 1976.
1966 F100 4WD, 1967/75 F100/250 4WD: The lower steering shaft connects to the input shaft of the steering gear box w/a clamp and thru bolt.
US Gov't mandated collapsible steering columns for cars beginning in 1968, but no F100/350, Bronco or Econoline has a collapsible steering column until 1980.
Old 07-06-2015, 05:15 PM
MIKES 68 F100
i got that info from the guys over at VMF vintage Mustang forum , they refer to the 65-66 mustang solid steering shaft as the impaler
Old 07-06-2015, 08:53 PM
rockpile's Avatar
rockpile
rockpile is offline
My buddy crashed a 65 mustang and it pushed him to the back seat and bruised his ribs. His passenger received four hundred stitches to his face. **** happens!
Old 07-06-2015, 10:22 PM
spdcat72's Avatar
spdcat72
spdcat72 is offline
The later Mustangs, 71 - 73, have a corrugated column tube and breakaway aluminum mounts under the dash to help it not impale you. All cars had solid columns until the early 70's. Just drive careful!
Old 07-07-2015, 07:28 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
I can see how it might work. Since the column and therefore the rag joint are at an angle (guessing 75 degrees from the front) and the force from a head on would be horizontal, the force would work against the rag joint. Not push it up.
Quick Reply: Rag joint? Shifter bushings?
