Bronco II Ford Bronco II
87 Bronco 2 dies when AC turned on
Old 07-04-2015, 12:51 PM
DocRoche's Avatar
DocRoche
DocRoche is offline
Working on my Bronco 2 for the 1st time today. Had some hiccups (no dip stick tube if anyone has a spare to sell). But I noticed when I first started it the day I got it it immediately died. Will run after hitting the gas a few times. I was originally thinking fuel pump. But when I tried the A/C today the truck immediately died. heater does not work. I knew this truck would be a project so I'm not to stressed. Any ideas on the dying with AC on issue?
Old 07-04-2015, 02:01 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
If you give it some throttle & the AC works normally, I would try cleaning the IAC/idle air control valve. The IAC is supposed to kick the idle up a bit to compensate for the extra load of the AC.
Old 07-04-2015, 02:18 PM
DocRoche's Avatar
DocRoche
DocRoche is offline
Ill try that. The AC does not work but I knew that when I purchased it. Whole truck dies the moment you hit the AC button though. Thanks for the advice
Old 07-06-2015, 05:50 PM
HappyJack's Avatar
HappyJack
HappyJack is offline
I should have a spare dip stick if you are close to south central ks. If not you might check your local salvage yard or car-part.com.
Old 07-06-2015, 06:35 PM
DocRoche's Avatar
DocRoche
DocRoche is offline
I appreciate that Happy but I have the dipstick. I need the tube it slides into. Nowhere around here has one.
Old 07-06-2015, 06:38 PM
DocRoche's Avatar
DocRoche
DocRoche is offline
On that note the truck seems to have issues starting cold. Turns over then dies. Requires some revving to get it to stay and a parked idle. Can't seem to figure it out but it almost seems like the truck isn't getting enough fuel at the start which requires the revving.
Old 07-06-2015, 06:44 PM
HappyJack's Avatar
HappyJack
PM me. I have 3 disassembled engines at my brothers place 30 miles east of me. Should have a spare tube.
Old 07-07-2015, 06:59 PM
DocRoche's Avatar
DocRoche
DocRoche is offline
Cleaned out the IAC valve, still the same issue. Truck needs the have some gas for a couple minutes before it will idle without dying. Once it warms up it idles normally. But it takes awhile to get to that point. Any suggestions would be great.
Old 07-11-2015, 12:57 PM
DocRoche's Avatar
DocRoche
DocRoche is offline
Update, fuel filter, plugs, and wires have all been changed. Same issue. Runs great and idles normal when warm, dies immediately when first turned over unless foot on gas.
Old 07-11-2015, 01:58 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
88 & newer b-2s and Rangers have a check engine light to let the driver know there is a trouble code stored in the ECM/computer. The codes can be very helpful for finding a problem.
Whenever I have a problem with my 87 Ranger I do 3 quick and simple tests:
1 Check for trouble codes
2. Screw on a fuel pressure gauge and check the fuel pressure
3. Test with a vacuum gauge.
If none of these tests are helpful for figuring out the problem, the truck goes to Castners auto repair in Yorba Linda, Ca.
Old 07-11-2015, 02:05 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Forgot to mention that I scanned thru the 99 trouble codes in my Actron code scanner book and unless I missed it there are no trouble codes for a bad IAC. I guess the ECM/computer doesn't monitor the IAC to see if it has a problem.
Sometimes cleaning the IAC will fix idle problems, sometimes it needs replaced.
But b4 I replaced anything I would do the 3 tests I mentioned.
Old 07-12-2015, 05:33 PM
DocRoche's Avatar
DocRoche
DocRoche is offline
I pulled the ACT and it was black and corroded. Hoping that may be something when I replace it tomorrow.
Southfork894x4
06-22-2012 09:45 AM
dep295
08-06-2008 06:11 PM
ironmine
Garage & Workshop
02-19-2008 07:17 PM
billyb
09-09-2000 11:41 PM
Quick Reply: 87 Bronco 2 dies when AC turned on
