Help!! New Batteries and Alternator... still no charge =(
Old 07-05-2015, 01:07 PM
Coz2122's Avatar
Coz2122
Coz2122 is offline
Okay... Do you know which harness that green/red wire leads into??
Old 07-05-2015, 01:20 PM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
remove the main charge wire put a large load on it...to see if it will pass current...it may have continuity but have high resistance, when fuseible links blow it is possible they leave behind a trace of powdered metal/carbon that reads with volt meter...
Old 07-05-2015, 05:05 PM
hturner12's Avatar
hturner12
hturner12 is offline
Originally Posted by Coz2122
Checked continuity and everything checks out ok. That's what I'm thinking too but I took it off and had it bench tested and they said it worked fine... Could their machine be faulty??
Yep. When I did my 3g upgrade I took the alt from the jy to autozoo. They said bad no voltage at all. Took it the Advance test good at 14 volts. Verified when I put it on 13.7 at idle
Old 07-06-2015, 10:07 AM
Coz2122's Avatar
Coz2122
Coz2122 is offline
So unplug the large female connector at the alternator and Check for voltage at the green wire... If there is not voltage than there is a fuse somewhere?? Does anyone know where the fuse is cause I can't find it anywhere
Old 07-06-2015, 01:16 PM
madpogue's Avatar
madpogue
madpogue is offline
That wire is associated with the dash warning light. So the owner's manual should mention which fuse is for that light. Also, I've read elsewhere that when that light burns out, it can affect the exciter circuit to the alternator. Does the light come on when you turn the key to RUN (engine OFF)?
Old 07-06-2015, 05:33 PM
Coz2122's Avatar
Coz2122
Coz2122 is offline
No. There is no battery light that flashes on... In fact there is no lights that come on in the cluster when in the on position (engine off)
Old 07-06-2015, 05:37 PM
Coz2122's Avatar
Coz2122
Coz2122 is offline
Here are my fuses. They all check out ok.
Old 07-06-2015, 05:39 PM
Coz2122's Avatar
Coz2122
Coz2122 is offline
Old 07-06-2015, 06:06 PM
Coz2122's Avatar
Coz2122
Coz2122 is offline
Do you know which fuse? I've check them All twice now and have not
Found any bad ones... Do you know which harness it leads into? I'm not getting any volts at the green/red connector
Old 07-06-2015, 06:40 PM
madpogue's Avatar
madpogue
madpogue is offline
Check the bulb for the charging system failure warning light.
You're not even getting a WTS light?
If no one with a '94 EVTM chimes in, I'll check my '95. It's for a PSD of course, but much of the circuitry for things that aren't specific to the type of engine (such as charging, accessories, etc.) are similar, so I'll check that for what fuse to check.
Are you checking for voltage at the terminal on the green/red wire with the key in RUN?
Old 07-06-2015, 06:50 PM
Coz2122's Avatar
Coz2122
Coz2122 is offline
I'm not getting any voltage at the green/red wire... And no my wait to start light is working I don't know if my battery light is. Although not long ago the wts light wouldn't come on. But then it started coming back on so I didn't think
Much of it
Old 07-06-2015, 07:32 PM
mroth2008's Avatar
mroth2008
mroth2008 is offline
Checked the instrument cluster an cab connector. And than if everything looks good and start back probing. Also maybe replace the fuse for the circuit, its cheap it may have failed and you cant see it.. Your on the right track at least.
Urban Monkey
10-08-2015 12:17 AM
Andy_W
6.4L Power Stroke Diesel
11-17-2014 08:58 PM
1965tontruck
Electrical Systems/Wiring
05-25-2010 05:24 AM
wisconsin
1997-2006 Expedition & Navigator
02-03-2008 09:59 PM
Redneck80
12-21-2003 05:17 PM
Quick Reply: Help!! New Batteries and Alternator... still no charge =(
