Still low oil pressure
Well, hooked up mechanical gauge, and oil pressure is still very low. The most it gets up to is 10. The oil pickup tube is new, not sure about oil pump. Motor is a fresh rebuild, but it was done 3 or 4 years ago. Any ideas? Pull motor and replace oil pump?
This pic is at idle cold motor. Pressure goes up to 10-15 if I rev it up.
It was missing an oil plug in the rear of the block. I pulled the transmission and plugged it. There's no oil leaks, so can't figure it out. I can't pull off the oil pan unless I pull the motor. .....if I remove the oil pressure gauge, oil shoots out of the port. So I know there's a little pressure...
Do I understand that upon discovery of the rear galley plug missing, that NO oil had poured out? hmmmmmm... To me this would suggest the oil isn't making it that far and, the Lifters and Rockers aren't oiling at all? I could be wrong.
The common check lists for low or no oil pressure are well documented so I'll just offer two things that come to mind.
I wonder of the "New" Oil Pump Pick Up Tube is kissing the Oil Pan Floor.
I bought a Windsor with no pressure once. I discovered the P.O. used a bolt that was too short when installing the Oil Pump. It pulled the block surface up at the threaded hole creating a gap. Some folks gasket the Pump and Pick Up Tube, some don't.
Good Luck
Good Luck
If a shop built it I would take it to them. I normally prime any new engine before starting, I like to see full oil pressure before hitting the key. Parts are going to get damaged running it like it is.
I had that problem once on a fresh rebuild. The reason for the rebuild was that the fiber timing chain gear had started to disintegrate and pieces had traveled thru the engine. I replaced the oil pump with a new one which fixed the problem. A later post mortem on the old pump revealed a piece of the gear tooth had become trapped under the pressure relief valve check ball so most of the oil was by passing the engine. Pull the valve covers and crank over the engine to verify an ample oil supply is reaching the rocker arms. Yes, the engine shoud have been verified as having oil pressure by the rebuilder.
I bought the truck in California, (motor came with it. Engine builder also in California), oil did come out of oil galley plug. That's how I noticed I had a leak. I will pull valve covers and see if oil is making its way to rockers. I did prime the motor before start, but had an electrical oil gauge so didn't see any oil pressure.
Good Luck
Good Luck
As Dave mentioned, there is an oil galley plug right behind the cam timing sprocket. I can't imagine why a galley plug would be missing on the rear, but it increases the odds the one on the front is missing. Pretty sure you could see if the plug is there by pulling the WP and front cover off.
Before you do anything, I'd verify that the gauge is working.
I just replaced timing cover gasket 2 weeks ago. Didn't know to look for another oil plug. I have used electrical oil gauge and mechanical gauge. Both read 10 lbs max
I guess there are actually 3 plugs up front.
How to tap the oil galley plugs on a ford 302 | SBF Building
Finally pulled distributor, is this an oil galley plug?
Thought that anyone reading this post may want to see the final resolution/cause of this low pressure condition...https://www.ford-trucks.com/forums/1...n-removal.html
