How to test oil pressure with a mechanical/manual gauge
I have had a noise from the engine when cold for a while now. It doesn't sound too threatening and the stock oil pressure Gage reads well within a safe range. However, I want to test it with a more reliable manual pressure gauge.
Where is the oil pressure sending unit on the 302? Also, do you have any recommendations for a cheap manual gauge?
The noise which is a "marble " type of noise has been present since I changed the oil 2x after I bought the truck. I've been using Castrol GTX 10w30. I don't know what the original owner used.
Is there a different type/brand of oil that is still within factory recommendation that I should try?
Thanks.
Thanks.
Thanks.
Thanks.
These trucks were made for 10W-30, so that's what I run. As for type or brand, do a bit of research and you will find that is a heavily-debated question. Some say that your cam and lifters have mated and the type of oil doesn't really matter. Others say that since the amount of ZDDP has been drastically reduced in standard oils you either need to run an additive or a high-ZDDP oil, like those for diesels.
Personally, on an engine with many miles on it, all presumably with a standard oil, I'd continue to run a dino or synthetic oil w/o any extra ZDDP. Like Mobil 1. But, if I were building a new engine with a flat-tappet cam I'd probably start with an oil with extra ZDDP, like some diesel oils, or run an additive.
Confused?
Confused?
