1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2015 250 rode rough so I checked tire pressure, Wow!
Old 06-28-2015, 09:52 PM
jbullfrog's Avatar
jbullfrog
jbullfrog is offline
More than just a Handyman
My left tires had 120psi front and back and the right had 80psi. I have 7000 miles on it. I admit I haven't check the tire pressures previously. My question is how the left two got that much over inflated. It hasn't been anywhere but the dealer and my shop.
Old 06-28-2015, 09:53 PM
jbullfrog's Avatar
jbullfrog
A display of tire pressures on the dash would be great for this! 60psi over inflated could have killed someone.
Old 06-28-2015, 10:15 PM
NYCruiser's Avatar
NYCruiser
NYCruiser is offline
They can't inflate themselves. Someone had to put that pressure into them.
Old 06-29-2015, 05:52 AM
RangersF250's Avatar
RangersF250
RangersF250 is offline
120 is above the tires recommend psi from the manufacturer, you're lucky they didn't blow. I believe my max psi is 80. I have Michelins.
Old 06-29-2015, 08:16 AM
jbullfrog's Avatar
jbullfrog
I know from experience and 3 trucks with tpms sensors on the stems, you have to hold a tire gauge correctly and check more then once per tire. If Ford isn't going to use the sensors it would be safer to leave them off entirely.
Old 06-29-2015, 08:53 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Do you have a faulty tire pressure gauge? I know heat will cause them to raise pressure, and I have seen some garbage trucks I used to work on that had tires rated to 130psi, and we maxed them out. On a hot day when they would come in, they exceeded my 150psi gauge. To go from 80 to 120 is a lot!
Old 06-29-2015, 05:19 PM
Jdeshler's Avatar
Jdeshler
Jdeshler is offline
120!? Wow, glad that didn't get bad on you
Old 06-29-2015, 06:10 PM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
Mine came from the dealer with 55 psi in all the tires. The tires say 80 & the door tag says 65. I upped the pressure to 70 & thought it rode way too rough. I also thought it did steer good when it was wet out. Every few days I've been letting a little air out to find the best ride. I'm down to 62 psi & think I'll stay there. I wonder if someone was playing a joke on you?
Old 06-29-2015, 06:19 PM
evan1242's Avatar
evan1242
evan1242 is offline
always go by the door sticker. that is a recommended pressure based on your particular vehicle no matter the max rating of the tire itself.
the rating on the tire is a max value.
Old 06-29-2015, 07:17 PM
Boss08v10's Avatar
Boss08v10
Boss08v10 is offline
When i bought my 08 in June of 09, upon getting it home home and thinking the same that it was sure rough riding. My front tires were at 110 and back at 95.
Old 06-29-2015, 07:42 PM
eberlestock's Avatar
eberlestock
eberlestock is offline
Wow! I run bout 40lbs to soften my ride. 30 when I go on long bush runs.
Old 06-29-2015, 09:13 PM
92f150I6's Avatar
92f150I6
92f150I6 is offline
I run 50 on all 4 tires, made a huge difference in ride, that and ditching the stock 235 85 r16's. The truck drove like poo with those tires.
Old 06-29-2015, 10:24 PM
Don Naslund's Avatar
Don Naslund
Don Naslund is offline
I used to go to 25 pounds since I never towed or hauled anything and because the center of the tires would wear out first.
Old 06-30-2015, 05:38 AM
Pit Crew's Avatar
Pit Crew
Pit Crew is offline
Air pressure is all over the board. How is it we don`t get premature tire wear. Back in the day tires called for 32 lbs.35 would wear the center and 29 would wear the edges. I realize tires have come along way, but these are some big differences.
Old 06-30-2015, 08:23 AM
moymurfs's Avatar
moymurfs
moymurfs is offline
Dealers will pump them up to prevent flat-spotting from sitting in one location too long. (the lot).
Quick Reply: 2015 250 rode rough so I checked tire pressure, Wow!
