More advice and an offer.
You can check with your tank's supplier, but I would think it should be made and sold ready-to-run. I would be disappointed to pay that kind of money and then be told I still have to seal the inside. It should be made from coated steel or other non-corroding material, ie; stainless, aluminum, plastic.
If you seal it, be sure the sealer is compatible with gasahol. Most of the sealing compounds were originally designed for use on light aircraft fuel tanks to reduce risk of corrosion from condensed water vapor on standing. Aircraft gas does not contain ethanol since ethanol is hydroscopic (absorbs water).
OARfan
10-21-2010 09:14 PM
Hot Water 6
15
06-07-2010 12:08 AM
