Replacement OEM Tow package wiring harness
Hi,
The socket that connects to my 7 blade tow socket is broken. I have it held together with zip ties, and that is working. But, I want to replace it, but I can't find a replacement part.
I ordered one from the dealer, but they canceled my order, as the part is no longer available. I have searched the net and the forums for a solution, but I can't find one. It appears that the superduty version is not wired correctly for an Excursion (mine is a 2001).
Has anyone replaced theirs, and knows of a good source?
Well, it looks like not many have had this problem. I'll follow up, though, with a potential solution. I sent this question to etrailer.com, and they recommended the part HM40975-11998. This part has the back connector, and you have to cut the existing wires, but I think it will work for me. It replaces the part of my wiring harness that is broken.
Here is a link to the question:
Replacement 7-Way Trailer Wiring Pigtail for 2001 Ford Excursion | etrailer.com
I got one recently from AutoNation Ford White Bear Lake | Ford Dealership in White Bear Lake MN .
Good luck!
The harness part is interchangeable with the superduty, Idk about the plug itself. I have swapped harness while troubleshooting.
Good luck!
BlackWidowMotorSports
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-13-2003 10:35 AM
