Wrench light, then oil light whats going on?
I have an 07 F550 truck has been running fine. Pulled it in to do a service. All new filters, oil fuel and air. I started the truck up it ran for about 5 seconds and it shut down. The wrench light came on then it displays the oil light right after. I double checked all my fluids. I even pulled the new filter out to check the o-ring and it's fine. Any clues to what could be my problem. This truck just had an engine swap this is it's first service.
Did you cycle the key 6 times for 30 seconds before starting it? After changing fuel filters you need to prime the system to get the air out. Sounds like the truck started, detected air in the system (or low fuel pressure) which triggered the wrench light and then when it stalled you got the oil light because there is no oil pressure when the engine isnt running.
TrekChick
02-07-2008 11:55 PM
robr0924
20
04-20-2006 06:54 PM
