Fuel Pressure Question
Hey guys
So I swapped in a new fuel filter. When we changed to the new one, we decided to leave the fuel pressure regulator off. It wasn't my idea, and the other guy helping me wrench didn't think we'd need it.
He was wrong... fuel pressure was pinging at about 9psi, which is way too high for the Edelbrock carb I have on the 352.
So I reinstalled the FPR, and I've got the pressure down to about 6.5psi. That's still too high as Edelbrock says it should be no more than 5.5.
I've tried loosening the nut on top of the FPR but that seems to do literally nothing.
I've taken the top of the carb apart as well and had a peek inside. It seems clean and good to go in there.
What should I be attempting next here?
Thanks
Thanks
If I'm not mistaken, the nut on your FPR is just a "lock" for the adjustment which it the center screw. The screw, with a slotted head, is awkwardly pointed towards your carburetor so you can't see it. If possible, re-orient the FPR so you can get to the adjustment screw more conveniently.
Thanks!
Fred_f250
06-23-2019 09:33 PM
ExPACamper
130
03-16-2016 05:57 PM
pinkpantherbeekeeper
06-18-2013 03:58 PM
fairfield86f150
07-11-2007 11:00 PM
